Changing date on 2022 Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Greg Weir, May 29, 2022.
  1. Greg Weir
    Greg Weir Junior Member
    San Diego
    2022 Prius Prime
    Hello,
    I recently bought a 2022 Prius Prime (Limited). Originally I had a 2005 Prius. This means a learning curve.
    My problem is with scheduled charging. I set the Start time and Departure, but it doesn't charge. I had thought I was missing a step, but when I looked at the display, it showed that the current day of the week is Wednesday (today is Sunday).
    Perhaps I set the wrong year when I was first asked, but I have no idea as to how to change the day to the correct one. If I change the schedule to Wednesday (and it will really charge on Sunday), that will work as a band-aid. I did a search and discussions are more about the clock or from 2012.
    Has this happened to anyone? If so, how do you correct it?
    Thanks,
    Greg
  2. schja01
    schja01 Senior Member
    1,849
    1,228
    Chicagoland
    2024 Prius
    Limited AWD-e
  3. aaf709
    3,862
    2022 Prius Prime
    Got my answer, see my post. I didn't realize I was already a member and created a new profile.
