DIY BSM blind spot Monitoring system Prius prime
Discussion in 'Prime Accessories and Modifications' started by GSP_Prius, Jun 3, 2022.
  1. GSP_Prius
    GSP_Prius New Member
    2022 Prius Prime
    disappointed that only limited has bsm -
    I’ve added aftermarket Blindspot monitoring system by pioneer. They have a few I picked the license plate adapter version.
    Works well enough. I haven’t yet tested cross traffic feature but assume it’s just as good.
    The install is similar to rear dash cam - if you are willing and capable.
    Cheers.
    can provide more details if interested, thanks
    tricky parts were connecting to safe power source, routing cable from device into cabin, identifying rear and left right signals. Took photos to show what I did.
    His&hers and Gokhan like this.
  2. GSP_Prius
    2022 Prius Prime
    Correction it reverse wiring… it’s the red wire. There are two (probably left and right reverse lights).
    However if you tap the striped wire… there is no signal but if you disconnect that wire- it will disable the rear lights, so that’s why I thought it was rear light… not sure what exactly it does.
  3. GSP_Prius
    2022 Prius Prime
    Final left right and reverse light wires for 2022 Prius prime EC90F100-F2F0-4389-B5EB-1C8946422005.jpeg
  4. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    White is usually ground wire
    GSP_Prius likes this.
  5. ascii27
    ascii27 New Member
    Awesome detail in your pics. Thanks. It's something to file away for the future for sure.
  6. Rocketboy235
    Rocketboy235 Junior Member
    34
    24
    MA, USA
    2022 Prius Prime
    I'm curious if one could go out and buy the OEM part for Toyota BSM and then add it to the Prius Prime LE/XLE and TSS2.0 will happily accept it without any fuss. I guess the other thing is figuring out how to calibrate it but as long as the lower trims can accept the OEM part, that's already pretty nice. Also would have to buy the sideview mirrors with the BSM indicator lights as well.
    Links just for reference (probably can get better prices elsewhere)
    2022 Toyota Prius Prime Collision Warning Sensor (Left, Right). BLIND SPOT MONITOR, LEFT; BLIND - 8816247040 - Genuine Toyota Part
    2022 Toyota Prius Prime Door Mirror Glass (Left). SPOT, BLIND, MONITOR - 8796147410 - Genuine Toyota Part
    2022 Toyota Prius Prime Door Mirror (Right). SPOT, MONITOR, PLATED - 8791047650 - Genuine Toyota Part
    Gokhan likes this.
