PCV removal/install instruction?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Pyro2k, Sep 26, 2019.
  1. Pyro2k
    Pyro2k New Member
    Austin
    Hello all! this is my first post of my first owner of 2016 Toyota Prius Two (fourth gen)- I will try my best to use English properly since it's my third language- I bought it in 2016 and have used it up at about 130,000 miles now- I had free oil change til 100,000 miles from toyota service- have been changed there oil regularly scheduled - after my oil voucher ran out after 100,000 miles- I realized they charge me 70 dollars for oil change- I went there for two times with paid oil change- I decided started my own oil change- I have used Toyota OEM Oil filter, and used Mobil1 Full Synthetic 0W-20- After about 15,000 miles My engine started having cold start vibrate every time i start it and also it get vibrate at somewhere highway or uphill in odd time, most time it's smooth- I had used bg44k, it did helped- but after two gas tanks, it came back- I suspected that pcv might is fault- because I found oil pooling in the pipe between the top of engine and on the intake hose- and found oil pooling inside of the intake hose which connect to the intake- only one line of oil pooling- not much- I have looked at the butterfly of intake- just regular dirty from carbon- cleaned it with cloth and intake cleaner-
    I have bought new PCV- I know where is PCV location- I have searched over facebook group, google, and this forum- I am not able to find any posts regards how to removal/install PCV without taking other parts apart? I am feeling that I have to take intake manifold out to change pcv?
    I have bought oil catch can- Will install it after all maintenance complete-
    I decided bought Toyota Oil SAE 0W-20 instead Mobil1-
    Please guide me and please give me any tips- thank you all!
    52,375
    welcome!
    if no one here knows, try techinfo.toyota.com
    all the best!(y)
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    From rooting around the Gen4/Prime engine bay, the PCV valve is buried behind the intake manifold:cool:.
    I’d remove the air intake and intake manifold and you’ll see the PCV valve;).
    Not easy to access, but might be worth considering the manifold cleaning while there:).
    Once you install the catch can, post up some pics of your handy work (y).
  4. Stripedshrimp
    Stripedshrimp New Member
    24
    Seattle
    Three Touring
    Do you know if you can access the PCV valve from underneath the car? Thanks
    Raytheeagle likes this.
  5. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Not sure :whistle:.
    But it is difficult to access the underneath of the Gen4 / Prime given the location of the center front jack point;).
    If you end up investigating, report back the findings (y).
  6. Mendel Leisk
    41,889
    Third gen you can, so maybe.
    Addendum: repair manual info attached.
    #6 Mendel Leisk, Jun 3, 2022
    CR94 likes this.
  7. Stripedshrimp
    24
    Seattle
    Three Touring
    Wow thanks for the great info!
    Looks like I'll be taking the intake off .
  8. Stripedshrimp
    24
    Seattle
    Three Touring
  9. Stripedshrimp
    24
    Seattle
    Three Touring
    I got underneath and took the plastic cover off. I looked and looked and looked but I could not find the PCV valve from that vantage point. ☹️
    CR94 likes this.
  10. CR94
    CR94 Senior Member
    2,742
    1,200
    Northwestern S.C.
    Looks identical to 3rd-generation PCV set-up ...
  11. Stripedshrimp
    24
    Seattle
    Three Touring
    I'm getting ready to do the PCV job this weekend. Is there any chance you could post some info about removing the intake manifold? Thank you very much
  12. Mendel Leisk
    41,889
    attached:
  13. Stripedshrimp
    24
    Seattle
    Three Touring
    Thanks. This information will be very useful even though I see it is for a third gen Prius and I am working on a 4th gen.. it will give me a general idea of the order of operation and torque specs .
  14. Stripedshrimp
    24
    Seattle
    Three Touring
    By the way, what is the name that software/manual that you are getting this information from? I would like to see if I could afford to buy it myself. Thank you again!
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    My daughter is bringing over her 2017 Prius this afternoon for her 6-month, 5,000 mile oil change. I have a new PCV valve from my dealer so will be seeing if I can get it swapped out.
    I do remember being told to always replace the throttle body gaskets if I ever remove it but I don't have them so if I can't get to the valve without doing that, will have to wait until I pick up one....or I can run down to my auto parts store and pick one up....don't think that part is crucial for OEM....I'll take pics and report back later.....
  16. Mendel Leisk
    41,889
    Missed this, my mistake. Attached is gen 4 Intake manifold and throttle body removal/install info.
    <<<Hitting the wall regarding throttle body removal, will try later. Torque for hold-down nuts/bolts likely same as gen 3 (info in earlier post)>>>
    #16 Mendel Leisk, Aug 24, 2025
    borgestes and ColoradoBoo like this.
  17. ColoradoBoo
    1,271
    879
    Yeah I got in there and got the air intake system off so I could get a good look at the throttle body and exhaust manifold. Unlike some previous Toyota models, there's no way to get under there to replace that PCV valve without removing it....bummer!
    So to do the job right, will need four gaskets...EGR inlet gasket, EGR pipe gasket, manifold gasket, and throttle body gasket.
    I'll get a couple sets of them (for our two Prius) ordered with my next car order.
    My daughter's 2017 Prius got the oil change and had 5,100 since the last time I changed it (5 months ago). Surprised by how clean that oil looked...this car's going to last a LONG time for her, thank Goodness.
    Always fun to drop stuff in those Toyota's...my 10mm socket came off and fell down there while removing the air intake box but I was lucky, able to reach in through the oil change cover to get it back...else that whole cover was going to have to come off.....ARGH....
  18. Mendel Leisk
    41,889
    If the miles are low, I wouldn't see any harm in reusing those gaskets. I did finally replace intake manifold gaskets (on our '10), the second time I had it off, but the the old ones still looked identical to the new.
    ColoradoBoo likes this.
