Dr. Prius Results Gen 2 2005 110,000 Miles
Discussion in 'Gen 2 Prius Technical Discussion' started by Sean2005Gen2CA, May 11, 2020.
  1. Sean2005Gen2CA
    45
    32
    Posting to update and keep a journal / timeline of the journey of the Prius! About a year and 20,000 miles later we are still on the road!
    January 12th, 2021 I charged the battery with the Prolong Charger (6 months after replacing modules / blades and reconditioning). With the charging assembly still attached to the battery, this follow up process of charging each 6 months is so much easier than before!
    On that first go, after confirming with a tech from Hybrid Automotive, I left the charger plugged in and running for 23 hours, as I noticed the charge stabilize for 2-3 hours at the end of this initial charge cycle.
    6 months later for the second charge, I did on June 14th. Just getting around to posting about it now. I charged for 24 hours. For anyone who hasn’t done this process and for next time when I read this in 6 months to remind myself, the 12V battery does not need to be disconnected during this process. It would only be important to disconnect it if the door was open and / or a light was on that was draining it.
    The tech at Hybrid Automotive advised me that the 12V is not affected by the Prolong charging process. Since I am, admittedly, not an electrician and don’t have the professional experience with how the HV and 12V processes overlap, this is an important distinction for me to make for myself in the process to be sure I am doing this correctly and safely.
    Here’s the Dr. Prius readings for the first drive after the charge. At the end of the charge the Prolong Charger read; 239V 343A.
    Cheers Prius Fam, we’re still on the road!
    Sanchan and davecook89t like this.
  2. Sean2005Gen2CA
    45
    32
    Hi Prius family! Back at it again -- Red Triangle came back a week ago so this time I'm load testing and would like to check in for your feedback before I reinstall the battery.
    I replaced 4 blades this time, 7, 8, 13, and 22 are the new ones. They're already in the pack and I made those replacements based off of Dr. Prius readings. I actually replaced those 4, then reconditioned with Prolong charger and discharger, ran the full cycle and 40 hour final charge. Let it sit for two days. Thought long and hard about confirming my work with load testing as I wanted to make sure that I replaced the right blades and double check my work with load testing this time so I don't end up missing a weak blade and having to do this again sooner than necessary.
    How do the numbers on the attached spreadsheet look good to you guys? To my surprise, one of the new blades, #8 showed the greatest voltage variance of the whole pack, is this something I should be concerned about?
    I load tested each blade for 60 seconds. First recording the static state, then where it registered on my multimeter after 60 seconds. I used a 50/100W sealed beam headlight gator clipped to multimeter leads. It's my first time load testing so I appreciate your advice on any other data I should be going for to determine if these blades are good to go / your suggested methods on how to best perform the tests for best results.
    Thank you,
    Sean
    nancytheprius likes this.
  3. Albert Barbuto
    102
    95
    Northeast USA
    I prefer to load test the pack while driving under load. The 1st pic shows full acceleration from a dead stop. The 2nd pic shows backing up a long hill, where the load is only 31.5 amp, vs 146 amp. I replaced module # 28 after these two tests, as numerous cycles via a hobby charger did not bring this module to life.
    Sean2005Gen2CA and nancytheprius like this.
  4. Mendel Leisk
    38,709
    Blade and module are the same thing?
    Sean2005Gen2CA likes this.
  5. nancytheprius
    nancytheprius Active Member
    356
    152
    iowa
    based on the context clues I think that is a safe assumption ;)
    Sean2005Gen2CA and Mendel Leisk like this.
  6. Sean2005Gen2CA
    45
    32
    Thank you for your responses!
    Albert, I will have to try that method once I reinstall. Thank you for the suggestion. I like the idea of testing under reversing and full acceleration to monitor performance in order to identify weak links.
    Mendel, yes, I've called these things so many different names - to be clear, yes blades = modules. I'm trying to confirm if I replaced the right ones or if there are any issues with the voltage differences that display after load testing. I've heard of people "shuffling the deck" to match strength of modules / blades and pair them together in their respective blocks. Would anyone be able to share experience on that or suggest that I do that given my data?
    Nancytheprius, thanks for joining the thread and helping out, any advice would be much appreciated!
    Best,
    Sean
    Mendel Leisk and nancytheprius like this.
  7. nancytheprius
    356
    152
    iowa
    I will first say that I have never actually reconditioned my battery. I have just read other posts in preparation for when my battery fails, if that's the route I take. From what I have read, shuffling the modules to evenly match after replacing bad modules and reconditioning all of them is important to making the fix last longer. I used excel to re order your modules. I matched the max value with the min value and then formed a block. Then I used the next max and min value and placed that block on the opposite end. Then I kept going back and forth with the next max and mins. This method assumes that your module 8 and 28 are fine (I have no idea). I also think it is better to use capacity of the module as opposed to just the voltage difference from the load testing, but I went off of what you have done so far. I think capacity is measured from specific chargers based on the milli-amp hours, but if you used the prolong charge I dont know if its possible to measure after the fact which is not the end of the world. Anyways let me know if something doesnt make sense. Please anyone feel free to correct me as well
  8. Sean2005Gen2CA
    45
    32
    WOW! @nancytheprius thank you so much for taking the time to match the modules up and share that with me! Modules 8 and 28 are both fairly new, 8 from when I replaced 1 or 4 last week, and 28 is a new one I put in 3 months ago when I swapped a couple out. I'm going to give the reshuffle a shot! I did not reshuffle or pair the blocks like this the last two times I've replaced modules so I'd say it's definitely worth a shot in hopes that it will help the fix last longer this time. Thank you and any other eyes on the prize here that have suggestions are always appreciated!
    For measuring milli amp hours, I believe the prolong charger has a reading for sure that displays that, but it's for the entire pack. Is there a way to measure modules mah individually? I will probably just go with the info I have currently but it'd be good to know for the future.
  9. nancytheprius
    356
    152
    iowa
    Report how the reshuffle turns out!
    Also, some people discharge and charge modules individually will smaller rc chargers and such. That is how you would obtain the mah values individually. So it's basically the same process as yours, but for each individual module as opposed to all at once. Takes a lot longer unless you have multiple chargers. Your charger is the grid charger and does the whole pack as you know. Anyways, I hope the reshuffling does the trick.
  10. Sean2005Gen2CA
    45
    32
    @jerrymildred @fotomoto @dolj @Mendel Leisk
    Just completed the reshuffle last night to match the data @nancytheprius provided. I emailed Hybrid Automotive asking if I ought to recondition the modules in their new order, and the tech said that I should not shuffle the pack.
    I mentioned a few folks who had been on this thread before to see what your thoughts are. I know I've heard it mentioned here many times about reshuffling and reordering modules to match. So I went for it as @nancytheprius awesomely put a matching list together based on my data for me.
    I reshuffled them last night and could install the pack back into the car tomorrow, but the Hybrid Automotive tech made me kind of nervous about it. I could put them back to their original order, as I had them numbered, not sure what to do at this point. Here's what the tech said;
    "Oh no, shuffling the modules is a really BAD idea, modules work in pairs you will have a lot of problems and if you dint a identify the modules you will have a never-ending stream of problems with the pack, doing a reconditioning after replacing modules its good and will not harm the battery, most likely it will not gain more from the process but at least they will balance, the thing is that modules have Amp-hour capacity and the capacity has to be almost the same from the two modules in the same pack, shuffling the individual modules around will really mess up the battery."
  11. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Sorry, but that's above my pay grade. I have never replaced modules. The only time I've had a failure, I replaced the whole pack so everything would match.
  12. Albert Barbuto
    102
    95
    Northeast USA
    I do not believe "shuffling" is a bad idea. In reality little is to be gained from this practice. The best action to take is to cycle the pack repeatedly, and then discard any modules that are much weaker. The pic below shows the effects of cycling an old, 2003 pack. The results are indisputable.
  13. nancytheprius
    356
    152
    iowa
    That tech's response is confusing. If you can't change the order of modules, then how can you replace modules?
  14. Sean2005Gen2CA
    45
    32
    Thanks @Albert Barbuto and @nancytheprius for your responses. I agree the tech's response is confusing and that discharging and charging is a best bet to promote longevity of the modules. Indeed new modules introduced the the pack changes the order. @Albert Barbuto thanks for sharing that data. When you say cycling, could you explain a little more what your process is? I see 12 discharges listed, are you charging the whole pack again after each discharge? Is this 12 discharges and charges of the entire pack? In my experience, this could take a week or two all together, as my usual reconditioning cycles of 3 discharges and 4 charges usually take around 4 or 5 days.
    In the end of this recent reconditioning cycle, I opted to go back to the original order of modules, with the four new modules added into the pack. Reordering them I broke a couple temperature thermistors off the bottom of the modules (DOH*) but luckily a helpful Prius Chat member was able to send me a couple of replacements to splice in. Pack is back in the car and running fairly smoothly for the last couple weeks. I say fairly because there have been a couple of curious displays of blue bars running up and down on the MFD. Watching the activity on the Dr. Prius App it shows a higher discrepancy in voltage variance (picture attached) and then a more mild discrepancy as I keep driving it seems to even itself out. Any feedback on the reading would be appreciated.
    Hoping for the best and expecting I'll probably need to pop another 4-8 modules in sometime in the hopefully not too soon future. At that point, I'll be close to having replaced the entire pack with new modules.
  15. Sean2005Gen2CA
    45
    32
    IMG_9679.jpg IMG_9678.PNG IMG_9682.jpg IMG_9680.jpg Block 5.jpg IMG_9679.jpg
    Hello again! 3 questions :)
    1. How can I identify why my temperatures are running higher?
    2. How can I better understand what everything means in the Hybrid Assistant report? Also, can this be transferred to my computer? I haven't seen an export option in the app.
    3. Block 5, is it bad enough to warrant replacing right now? (hybrid assistant picture attached) It didn't appear as bad as the previous 4 modules I swapped out during this repair, meaning, hybrid assistant did not implicate it as requiring attention until now.
    Just replaced 4 modules and reconditioned the pack this week. Had a red triangle moment last weekend. Just put everything back together, started up no triangle, which is always a good feeling, but seeing temperatures higher than normal;
    Typically they read in the 70 degree range, currently all three are in the 100 degree range. Not sure if this is due to the reconditioning process I completed over the week or if it's the warm weather, or something else. Temperatures stayed consistently around 100 degrees for the three temperature sensors on my first 15 minute test drive. It was around 90 degrees today ambient temperature but during the test drive it's around 60 degrees outside. (side note I cleaned the HV cooling fan thoroughly about 2 years ago... I don't have animals so I don't expect that it got too dirty or clogged at all)
    I had been using Dr. Prius, but recently resurrected an old android phone to use Hybrid Assistant. Getting a wealth of information from the reports there but I'm also looking for a walkthrough for better understanding all of the report information. Does anyone have a tutorial for reading the reports / downloading them? I'd love to share the full report here for feedback as well :)
    Thank you,
    Sean
    #55 Sean2005Gen2CA, Jun 12, 2022
  16. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Looking at your images nothing stands out to me. Maybe another top balance (charge until voltage remains unchanged for 4-6 hours) might close the voltage difference, but as it stands the difference is only 0.1x V which is well within spec. I would be very happy with those results.
    The way these apps graph the voltages tend to visually exaggerate the difference between the max and min voltages.
    Block 5 only seems to be flagged because it is the worst of the blocks, but 'worst' is very relative. Even though it is the 'worst' it is still acceptable.
    I'd say button it up and just drive it for a while then review where each block is at.
  17. jerrymildred
    11,508
    14,110
    Tampa, FL
    Did you clean the fan when you had it apart? The three most likely reasons for a hot battery are dirty fan, blocked air intake, or a hot cabin. Looks like the air intake temperature is OK, so that leaves blocked intake or dirty fan.
    That said, those temperatures are not all that high. As temperatures rise, the fan speed will increase till it's eventually loud enough that it will be very audible. And if the fan still can't keep up, it'll throw a code and light a light on your dash.
  18. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Yes focus on the Dr Prius voltage difference and the internal resistance data. Dr Prius graphics leave a lot to be desired with their exaggerated scaling.
    Neither diff nor IR seems bad, in fact the IR looks very good.
  19. drone13
    drone13 Active Member
    140
    115
    SoCal
    I don't think that's the real, measured IR. In my testing with the Dr Prius app, when it shows 19 across all cells for IR that is the default starting point (place holder) until the app has been run long enough to get an actual reading of all the modules. If you look at his first post from May 2020 it shows the same 19 IR on all blocks and yet the pack was pretty bad at the time with excessive VDiff and an obvious bad block 13. I think the car needs to be driven more with the DR Prius app running to see the real measured IR.
  20. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    In general, if the battery temperatures go higher than what the engineers want, then the fan will turn on. 100°F ain't much to bother with.
