Abs lights and speedometer not reading
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RaymondDaG, Jun 24, 2022.
  1. RaymondDaG
    RaymondDaG New Member
    Hey guys my two front speed sensors aren’t reading I already changed them and checked if there was power which there was but the computer is still not picking it up. I plug in my scanner and I can see the rear speed sensors picking up the speed but nothing for the front sensors. I’ve already checked out the wiring and nothing seems to be cut and when I reset the memory the lights instantly come back on.
  2. Eddie25
    Eddie25 Active Member
    496
    208
    MI
    It's a passive sensor right? How did you test for power, DC bias voltage at the sensor itself?
    Did they both go out at the same time?
    The lights instantly come back on meaning the wheels don't even need to turn, right?
    I think that would indicate an issue with the bias voltage (based on my limited knowledge of how speed sensors work).
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Need better wheel bearings
