How to prevent the 3rd Gen Prius Headgaskets failure!
Discussion in 'Gen 3 Prius Main Forum' started by Kaptainkid1, May 14, 2022.
  1. ChapmanF
    18,458
    Some of that noise was probably from the intake manifold too.
  2. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    Did it also blow out a nasty black cloud under the hood? You may have stumbled onto a short-cut clean-out method. imagine plugging the tailpipe at the same time ...
    Lares_Mat likes this.
  3. Lares_Mat
    Lares_Mat Member
    199
    59
    I like this idea :D
    If it would blow a carbon cloud into the motor compartment, it would not be nice thou - some filter or dustbag would help then ;)
    Mat
    CR94 likes this.
  4. Mendel Leisk
    41,826
    A pipe dream?
  5. seatbeltfastened
    seatbeltfastened Junior Member
    i find it interesting i see no mention of this, and at my shop we have seen numerous times. Car commands water pump on, shaft is spinning so prius pea brain thinks everything is AOK. We replace these as preventative maintenance all the time based on our experience
  6. Lares_Mat
    Lares_Mat Member
    199
    59
    You mean the water pump failing? On this photo I see the impeller dis-attached itself from the shaft, so actually no engine cooling should happen in this case.
    Would the ICE not overheat almost immediately?
    OK - Prius has no water temperature gauge, but most of us are driving with some sort of additional gauges like HybridAssistant or ScanGauge.
    If not, even if the "shaft is spinning so prius pea brain thinks everything is AOK", the "pea brain" has measures to discover the overheating of the engine.
    Can it lead to a blown head gasket?
    Mat
  7. bisco
    52,286
    is this solved in gen3?
