Front seat removal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JerryCS, Nov 20, 2009.
  1. JerryCS
    JerryCS Prius camper with trailer hitch
    76
    Elk Rapids, MI
    PriusChat rocks!
    Amazing this hasn't been a topic yet, but I hope you don't need to know for the same reason I did-- spilled milk under the seat. We needed to clean deeply and thoroughly, so I removed the front passenger seat. In a thread on extending seat rails, I found this link to a Toyota service manual with all the pages on removal, disassambly, reassembly and install of the front seats.
    http://jaygroh.dreamhost.com/prius/...epair Information/Repair Manual/SE - Seat.pdf
    The hardest part is disconnecting the cable from the negative terminal on the accessory battery. The glovebox owners manual shows the location, in the rear to the right of the spare tire well. Getting your #10 wrench on the nut is the hard part. I wished I had a stubby open end. Can't fit a socket wrench in there. Be sure to wait for two minutes after disconnecting the battery before working on the seat bolts and disconnecting the two wiring harnesses under the seat.
    Jerry
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    I found it easier to disconnect the end of the ground cable where it is bolted to the body. You are right that it is cramped at the terminal.
  3. VerroV
    VerroV New Member
    Oslo
    Does both the 12volt and the hybrid battery need to be disconnected to remove the front seats?
  4. dolj
    dolj Senior Member
    7,646
    3,858
    Wellington, New Zealand
    No, only the 12 V.
  5. VerroV
    VerroV New Member
    Oslo
    Great thank you!
  6. ChapmanF
    15,569
    If it's a Gen 2, the clamp on the + battery terminal has two plug-in connectors you can simply unplug. Less fuss than a 10mm wrench whether on the clamp or the ground bolt.
