Inverter coolant milky
Discussion in 'Gen 2 Prius Main Forum' started by beef jiggles, Jul 2, 2022.
  1. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    9E4464CD-DBE3-4FCA-98D7-7103A8B45EED.jpeg My coolant came out looking like this… what might be the cause?
    #1 beef jiggles, Jul 2, 2022
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Like what? A picture might help.
    Either way, I can't see how anything besides dumping the wrong stuff in the tank would contaminate inverter coolant.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    That's looks like an oil-coolant emulsion. I can't think of any reason for any type of oil based substance to get in the inverter cooling system unless someone added it. (Doesn't look like stop-leak or anything). Too much oil in a cooling system can attack and degrade rubber hoses and water pump seals.
    Even if there was some kind of one in a million cracked transmission case, I wouldn't expect trans oil to get pushed into the coolant- rather the other way around. (Might want to check the trans oil level and condition anyway.)
    It can be very difficult to clean oil out of a cooling system. Lots of water flushing, some gentle degreasers (Simple Green?), more flushing. Then refill with fresh Toyota pink coolant and bleed.
  4. bisco
    52,351
    maybe someone topped up with their milkshake in an emergency
  5. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    For all I know it’s whole cow’s milk from the factory in 2001.
    I ran a hose through it for a while then cycled new Toyota pink coolant through after replacing the pump.
    Was mostly curious if anyone had ever seen that before. It’s definitely oily.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,806
    838
    Southern California
    I don't have a diagram handy, but doesn't the inverter coolant loop also run through the transaxle case? Not sure that is the right term, the place where the two electric motors live. That is filled with an oily substance. If that was leaking into the coolant it might produce that milky white. More to the point, if the coolant was in turn leaking into the transaxle case that might be bad for the components located within. Especially if it chews up insulation, or causes spots to overheat.
    Diagram here, that component underneath the inverter where a hose goes in and another comes out:
    Inverter coolant and engine coolant flowing through the same radiator? | PriusChat
  7. mr_guy_mann
    4,086
    1,997
    NJ-USA
    Yes I've seen it, just never in a Prius. Usually it's the result of a leaking oil or transmission cooler.
  8. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    Its usually the other way around, coolant is pressurized and transmission fluid is not. Have had that on multiple beaters in the past. Coolant always leaks into the transmission, not the other way around.
    I'm guessing the 19 year old dumbass who sold me the car just put oil into the wrong reservoir.
    Data Daedalus likes this.
