If my Prius isn't burning oil will there be oil in the intake manifold?
Discussion in 'Gen 3 Prius Main Forum' started by bootsncats24, Jul 13, 2022.
  1. bootsncats24
    bootsncats24 Junior Member
    36
    Phoenix
    Planning on taking apart my Prius this weekend to clean out the egr system and from the videos I've seen and the forum post there is always some oil in the intake manifold. Since my car isn't burning oil is there a chance of oil in the manifold or just carbon build up?
    nicoj36 likes this.
  2. CR94
    CR94 Senior Member
    2,752
    1,207
    Northwestern S.C.
    Yes.
    I predict you'll see oil that looks relatively clean near the throttle body, and oily black mess farther downstream.
    mikey_t likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
  4. bootsncats24
    36
    Phoenix
    Thanks guys.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    What year is it? How many miles on the odometer?
    As stated, there's always a pool of oil in the intake manifold, under the throttle body.
    While you're in there, it's a good time to install an oil catch can. That will help with some of the oil getting into the intake manifold, which burns in your combustion chambers and causes carbon fouling, which can seize your oil rings, and lead to oil burning.
    Half Vast likes this.
  6. rjparker
    10,542
    6,617
    The low tension piston rings combined with a low mounted pcv allows the intake manifold to act as a catch can. Even an aftermarket catch can will not totally eliminate this design flaw, one of many in gen3s.
  7. Mendel Leisk
    41,926
    The intake manifold will have a pool of oil at the bottom, supplied by the PCV system.
    The EGR components, and the EGR passages through the intake manifold, will have carbon build-up.
    I'd second the question asked above: what's the miles?
    You might want to do the intake manifold one weekend, the main EGR system another. And an Oil Catch Can yet another. Simply because each can get involved. In particular the OCC. I would leave that to last, but don't procrastinate.
    More info in my signature.
    mikey_t likes this.
  8. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    It's been mentioned in other threads that 2015 models with the new pistons and rings don't suffer from clogged EGRs, but if the PCV is still also expelling some oil do you think the issue is just being kicked down a longer road?
  9. Mendel Leisk
    41,926
    I’m sceptical of that.
  10. bootsncats24
    36
    Phoenix
    2014 with 105k miles. Cleaned out the intake manifold and the egr pipe. Soaked both of them in degreaser over night and they looked good as new. Will probably wait to do the egr cooler. EGR pipe barely had any carbon on it so I’m hoping the egr cooler is the same. Also changed the PVC valve since the intake manifold was out along with the spark plugs.
    mikey_t likes this.
