Clunk sound front passenger just past warranty!
Discussion in 'Prime Main Forum (2017-2022)' started by Storm88000, Jul 15, 2022.
  1. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    Guys I am getting a clunking sound from the front passenger side area when turning & simultaneously going over bumps. 2020 Prime just past the 36k bumper to bumper.
    Car was just at Toyota today for fresh oil change, and even though it was already on the lift they wanted $149.95 *just to look at it!* I said no thanks. So I left l, we put it up on the lift at my friend’s shop and we couldn’t find anything obviously wrong. Wheels had no play and everything looked good. Took my friend for a quick ride and was able to replicate the sound by going over a speed bump - so I’m not going crazy. Yet. It’s not a LOUD sound, but you can hear it if the radio is low and can “feel it” thru the steering wheel. Is most noticeable when turning LEFT onto a bumpy road. No sounds at all as long as I’m driving straight. No pulling to left or right. No shake in the steering wheel. Doesn’t matter if I’m in D or B mode.
    Has anyone encountered this issue? And if so what was it? He is a professional mechanic and suggested getting new sway bar end links, and go from there. Or that it could even be the strut?? 2 years old? I don’t understand.
  2. Gokhan
    Gokhan Senior Member
    6,135
    2,428
    Paramount CA
    It shouldn't happen unless you hit something, like a curb when you're parking.
  3. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    What do you mean? I didn’t hit a curb but what would be making that sound?
  4. Gokhan
    6,135
    2,428
    Paramount CA
    You might have hit a speed bump, pothole, curb, or such. Something is probably broken and needs to be replaced. It could be as simple as a broken bolt.
    Storm88000 likes this.
  5. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Got it. Thanks. And yes I did hit a pothole awhile back that I recall but the clunk took awhile to develop.
    Gokhan likes this.
  6. Gokhan
    6,135
    2,428
    Paramount CA
  7. prius16
    prius16 Active Member
    462
    245
    New England
    2022 Prius Prime
    Take a video of the noise, and post it.
    Otherwise, best bet is a sway-bar bushing end-link.
    Fwiw, bad sway-bar bushings, or end links, behave exactly as you've described.
    Struts very rarely make noise when they go bad.
    It could be a strut bushing plate up top.
    Imho, I'd start by replacing all of the sway-bar bushings and end links.
    They aren't "very expensive", and they are, by far, the most likely cause of the noise.
    Also, they are "wear items". But, imho, in general for a Toyota, they should last at least 10 years and 100K miles.
    Btw, if it was a POS GM car, I'd say the sway-bar may be cracked/broken.
    Yea, apparently, making a sway-bar, is far past the ability of GM to do.
    Good luck!
    GSK likes this.
  8. Trollbait
    12,499
    Had to replace both of those during the time I had the HHR. The end links are easy to replace, in that they are easy to get to. The bushings depend on whether other things are in the way.
  9. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Someone said it’s the CV joint bushings and that would be powertrain?
  10. Gokhan
    6,135
    2,428
    Paramount CA
    I don't think CV joints have bushings, but bad CV joints make a periodic clunk–clunk–clunk–clunk noise when turning but not when going over a bump.
    These are the Prius Prime suspension components.
    FRONT SPRING & SHOCK ABSORBER. 2020 Toyota Prius Prime | Toyota
    #10 Gokhan, Jul 16, 2022
  11. prius16
    462
    245
    New England
    2022 Prius Prime
    Nope, typically, a CV joint will make noise when turning in one direction only, and typically only around corners.
  12. prius16
    462
    245
    New England
    2022 Prius Prime
    Things to check, in order (part#'s for one side, do both sides):
    48820B
    48811
    48815D
    48824A
    48603
    Then, for the lower control arm:
    FRONT AXLE ARM & STEERING KNUCKLE. 2020 Toyota Prius Prime | Toyota
    - Where the lower control arm mounts to the front subframe - look at both bolt/nuts and bushings.
    - The bushing near bolt 48068M eventually tears, But, a Toyota will typically go well over 200K miles, with no problems at all, on the lower control arm.
    - Ball joint
    Good Luck.
  13. schja01
    schja01 Senior Member
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    Nobody's mentioned a possible ABS/VSC issue.
  14. Trollbait
    12,499
    How would brakes lead to a clunk sound?
  15. schja01
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    The “B” in ABS?
  16. Trollbait
    12,499
    ABS and VSC are the computer controlling the brakes. I am unaware of an issue with the brakes that can lead to a clunk noise over bumps or when turning.
  17. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    A very slight clearance or "tight but not quite tight enough" in any suspension bolt or bushing can make a noise like your head is in a bass drum. It can't be found by the usual methods of wiggling things. I agree with the thought of replacing the parts that are most likely and lowest cost. Also, check that everything is tightened to spec.
    Gokhan and Trollbait like this.
  18. Gokhan
    6,135
    2,428
    Paramount CA
    In a new car, it's probably a broken part like a bushing. I had the rear-toe-set-in cam bolt broke on my 1985 Corolla once when I hit a curb, and it would make a sound. The technician found it immediately. Some suggested the stabilizer-bar end links or bushings, but it could be the strut or spring mounts, steering parts, or pretty much anything. Have the dealer fix it.
  19. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I haven’t noticed a difference between being in D or B mode - just the road conditions
  20. BiomedO1
    3,454
    1,797
    SacTown, Ca
    Check that sway bar bushing and sway bar rod. Also retorque the top strut bolt(s) to the body.
    Your steering geometry changes when the wheel is turned and it is bumping or rubbing against something. It's difficult to nail down on a lift, since you've taken all the weight off the suspension. If you know anyone with an oil change pit - you can watch the articulation as someone up top turns the wheel. This should also work on a wheel alignment rack. Local Les Schwab??
    Hope this helps...
