Mileage brags - personal bests or unusual highs
Discussion in 'Prius c Fuel Economy' started by michael.sfo, Nov 8, 2018.
  1. simpske
    simpske Junior Member
    27
    Illinois
    2022 Prius Prime
    Only had it a few days. Best so far. 26893253-6CA4-49FA-9F31-196B972E30F0.jpeg
    Pri3C likes this.
  2. Caesar753
    Caesar753 Junior Member
    Quincy, MA
    2015 Prius c
    Just got back from a 2,000 road trip and averaged 50.6 mpg. Not bad if you ask me!
    Pri3C likes this.
  3. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    Pri3C likes this.
  4. simpske
    27
    Illinois
    2022 Prius Prime
    Pri3C likes this.
  5. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    The autumn stars must have aligned today, because this might be my best highway fuel economy yet. It was a beautiful day.. not windy but nice and breezy. I snapped this as I was coming into town to run errands. I stayed in the 60s while there and was still above 55mpg when I got home. Trip was 80 miles total - 70 highway (cruising @ 58 mph) + 10 city.
  6. BlueCoast
    BlueCoast Junior Member
    26
    New Zealand
    2014 Aqua
    Probably my best fuel tank ever. 1005.4km (624.7mi) travelled, 29.89L (7.9gal) pumped.
    That is a fuel economy of 33.64km/L / 2.97L/100km / 79.12mpg(US)
    priusCpilot likes this.
  7. BlueCoast
    26
    New Zealand
    2014 Aqua
    Driven at 79mpg (34km/L) average for long enough that my range-o-meter had reset to over 621 miles (1000km) for the first time after my latest refuel! IMG_20241214_232944.jpg
  8. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    There is no way man
  9. BlueCoast
    26
    New Zealand
    2014 Aqua
    My range meter displayed 1013km (623.4 miles) after this morning's refuel. 31.5km/L (74.1mpg) average over 875.1km (543.8 miles) travelled. This is the third time in a row that the range meter reset to over 1000km (621 miles) after refuelling.
    e7663850-07c2-43a3-91db-c81e2e9ef7bb.jpg 1446593b-4ed0-4964-b7e9-7c4e2fc25e29.jpg 0cbe2313-6ddc-4ed6-9b84-6aca606441fe.jpg
    I get why it may sound unbelievable. I've been improving my driving for the better part of a year to get this type of fuel economy and range - a mix of smooth driving, carefully selective ICE usage, choosing optimal routes, patience, and consistency!
    MAX2 likes this.
  10. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Excellent result!
    Do you use any software product to record your daily car trips?
    BlueCoast likes this.
  11. BlueCoast
    26
    New Zealand
    2014 Aqua
    Thank you! Yes. I use the Hybrid Assistant app paired with an OBDLink LX OBD2 scanner. As long as I remember to use the app on my phone whilst driving it will record all the car's stats during the trip.
  12. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    I use the Hybrid Assistant.
    In the reporter menu function, you can display data for several trips. Have you ever tried to combine an array of data for a period?
    I wonder if the calculated data of the hybrid assistant matches the readings on the dashboard about fuel consumption per distance.
  13. BlueCoast
    26
    New Zealand
    2014 Aqua
    I just did a report aggregating my prior 90 trips all the way back to mid-December. The fuel economy average is almost bang-on accurate to today's calculated result.
    Comparing photos of my dashboard to my entries on Fuelly throughout 2024, I had come to find the dashboard's fuel economy display consistently overestimates by 1.5-2.0 km/L (3-5 mpg).
    MAX2 likes this.
  14. Mysteryos
    Mysteryos Junior Member
    Mauritius
    Toyota aqua 2022. Blown away. The a/c was on during the whole trip. That's 77mpg. 20250220_133902.jpg
  15. BlueCoast
    26
    New Zealand
    2014 Aqua
    A rare instance where I averaged 90 mpg on my short 4.58 mi commute this morning. Short trips with a cold start normally result in bad fuel economy because of the engine warm-up cycle. However smooth traffic flow helped me average it out.
    Post-trip photo of my ever-overestimating dashboard: 40.2 km/L (94.5 mpg):
    Screenshot of Hybrid Assistant's more accurate trip report (converted to US imperial units) with some relevant driving information highlighted:
    #95 BlueCoast, Mar 2, 2025
  16. BlueCoast
    26
    New Zealand
    2014 Aqua
    New PB!
    34.43km/L / 80.98 mpg
    833.8 km / 518.1 mi
    24.220 L / 6.398 gal
    IMG_20250320_120623.jpg Screenshot_2025-03-20-12-09-49-458-edit_com.google.android.gm.jpg
