Price to replace abs pump and module. c1391 c1391
Discussion in 'Gen 3 Prius Main Forum' started by JBuckPrius, Jul 20, 2022.
Tags:
  1. JBuckPrius
    JBuckPrius Junior Member
    64
    Knoxville, TN
    What should I pay to replace the ABS pump and module on my 2012 Prius w/ 177k miles? I'm in Knoxville TN.
    Dealership quoted $2500+/-. Parts are 04008-11347 brake repair kit $951.41 and 04006-22147 brake pump assembly $692.62. Labor $840. I know online parts are much cheaper after a quick Google search. How many hours labor should this be?
    I'm getting the c1391 code and have the brake light, abs light and traction light lit on the dash.
  2. JC91006
    JC91006 Senior Member
    16,780
    8,575
    Someone else might have better information, but I think Toyota extended this warranty to 200k miles (some lawsuit)
    JBuckPrius likes this.
  3. rjparker
    10,241
    6,395
    The only recent class action settlement (July 2022) extends inverter coverage on 2010-15 Prii to 20 years and covers extras like rental cars. Enhanced payments are delayed until January but Toyota already covered the flawed gen3s for 15 years.
    In a similar manner, brake boosters settled last year but consumers only received the pre-existing Toyota Customer Support Programs related to the flawed brake system. It did have an unlimited mile warranty but expiration dates passed for the hatchbacks and v wagon. Now "secondary" coverage is ten years from first use or 150,000 miles, excluding all 2010 cars and most 2011s even if under 150,000 miles.
    The miles limitation also excludes the majority of 2011-2015. As Toyota already settled the brake booster class action, there is little chance for more coverage.
    Since Toyota was paying for most brake boosters through last year on the unlimited provision, an aftermarket solution, new or remanufactured lacked financial viability. Maybe Dorman or some enterprising shop will jump in and make some dollars.
    Many online Toyota parts departments now offer reduced price oem master cylinders and pumps. Some Priuschat pundits suggest changing only the master cylinder after listening for leaks; Toyota replaces both parts which seems logical.
    #3 rjparker, Jul 20, 2022
    JC91006 likes this.
  4. JSB_99
    JSB_99 Member
    66
    48
    Houston
    $2500 from a dealer is actually a good price. I paid $1900 at a hybrid shop that used new Toyota parts and have heard of dealers charging $3k to $4k.
    saneesh8 and JBuckPrius like this.
  5. JBuckPrius
    64
    Knoxville, TN
    It looks like I can get the two oem parts shipped to me for about $1211, based on a search on google. That would save me about $400+ compared to the local dealer. If I brought the parts to my local mechanic how many hours labor should I expect this job would take?
  6. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    $2500 is a very decent price for that job. To be honest I would not just trust any local mechanic to do this job. Only go with a local if they specialize in hybrid work, specifically 3rd gen Prius. The dealership will usually warranty the parts and labor if things do not work after install. It’s much harder to hold a small shop accountable. Good luck and keep us updated!
  7. JBuckPrius
    64
    Knoxville, TN
    It's a large shop and I know they have a dedicated Prius mechanic. But I see your point. Thanks
  8. rjparker
    10,241
    6,395
    I think it is about six hours book time. Make sure they have Techstream or equivalent to calibrate and bleed the system. Toyota mechanics have some special tools to aid the process but others can't buy them. So the time can take longer especially if the tech has not done it before.
    8BB5F447-8CBB-4FC2-BA05-C99F3E494618.jpeg C5BF037D-C59D-4EC4-AC43-F9B00DFE2923.jpeg
  9. JSB_99
    JSB_99 Member
    66
    48
    Houston
    The one I used did it in about a day but they are a hybrid specialist and do these regularly so much that they keep the parts in stock. They didn't break down the labor on the invoice but I dropped it off after they closed on a Thursday and it was ready Saturday morning and that was with them working it into the schedule because they were so busy with other stuff.
  10. ChapmanF
    18,317
    In another recent thread, somebody 3D-printed that nut installer tool. Maybe they'll publish that on Thingiverse or somewhere
  11. JBuckPrius
    64
    Knoxville, TN
    Does anyone know where they have part 04008-11347 in stock? 3 dealerships I spoke to said they are not stocked and will take one to three weeks if they order it.
  12. bisco
    52,096
    it has been a big problem in the current climate
  13. JBuckPrius
    64
    Knoxville, TN
    I am going to give it a go with Airport Toyota. https://www.rickmcgillairporttoyota.com/
    I have an appointment for next Friday. Hopefullythey can obtain the pump assembly/brake booster part by then.
