Best mod under $100
Discussion in 'Gen 2 Prius Accessories & Modifications' started by PRINUS, Nov 17, 2006.
  1. PRINUS
    PRINUS New Member
    Hello, I'm wondering what is considered the best bang for teh buck mod, under $100. Anything that helps anything pretty much, lighting performance, suspension, etc..
    Also is any one making a turbocharger for these cars? Nitrous?
    thank you
  2. dreichla
    dreichla New Member
    2,230
    Connecticut
    Yea - there's a Nitrous Oxide mod for about $99.99 - plus tax and shipping. I've been laughing ever since. You gotta get it!
  3. PRINUS
    PRINUS New Member
    <div class='quotetop'>QUOTE(dreichla @ Nov 17 2006, 01:30 PM) [snapback]350915[/snapback]</div>
    Link please?
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I clicked on "Buy both now" on Amazon and got the turbocharger and Nitrous for only $110 if you wanna go just a little over budget.
    If this is a serious question from an "other, non-hybrid" owner who just signed up yesterday and has made only 2 posts and couldn't possibly be a troll, then I'll give a quick answer to that.
    I'd get the EV button and an engine block heater...you should have enough pocket change for a nice down payment on a display hood.
  5. PRINUS
    PRINUS New Member
    <div class='quotetop'>QUOTE(efusco @ Nov 17 2006, 01:56 PM) [snapback]350945[/snapback]</div>
    Sorry, no, this is serious. I'm just having a little trouble navigating through this board.
    I asked because I think every car made can be improved with relatively cheap modifications.
    But I agree a block heater is a good thing to have, I'll do some research.
  6. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    In Alabama, then I'd skip the block heater, and go for a wheelskin. It really dresses up the interior and just feels good on your hands when you drive.
  7. Alric
    Alric New Member
    1,526
    87
    I'd go for the sharkfin antenna. It makes a remarkable difference on the general looks of the car. You can find a good write-up here:
    http://evnut.com/prius_antenna.htm
    Cheers!
  8. Suckit Trabeck
    Suckit Trabeck New Member
    <div class='quotetop'>QUOTE(Beryl Octet @ Nov 17 2006, 02:10 PM) [snapback]350972[/snapback]</div>
    Would the block heater improve gas mileage? Or would a colder block be more efficient?
  9. PRINUS
    PRINUS New Member
    Good link Alric! Sporty yet sophisticated!
    Suckit, I think a warmer block would mean better mileage but less performance.
  10. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    The idea of a block heater is to warm the engine before you start it - this reduces warm up time, which in turn increases your mileage. a warmer engine is better than a colder one.
    For people in southern states, it's not that big of an issue. a block heater only starts showing some measurable improvement when the temperature drops down to freezing or below at night. So Alabama and Georgia probably shouldn't be concerned about getting them.
    *quick edit*
    PRINUS, a warmer block is better all around - an engine works best in an optimal temperature range, which is definitely not freezing or below. Also, having a warm engine is definitely better for performance. Anyone up north can tell you that all cars suffer from performance decreases when winter comes, and only start behaving like "themselves" when the engine gets warmed up.
  11. Suckit Trabeck
    <div class='quotetop'>QUOTE(eagle33199 @ Nov 17 2006, 02:21 PM) [snapback]350986[/snapback]</div>
    True. That makes sense. I don't know about the shark fin though, it does look a lot better than the stock antennae but not sure I want to drop $100 bucks on one.
  12. PRINUS
    PRINUS New Member
    Well it sure looks more aerodynamic, and flows with the lines better. Maybe enough people are interested for a group purchase?
  13. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I'd do little things to reduce the weight: take the plastic trim off the wheels, take out the spare (if you're willing, and carry a can of flat fixer instead)) and the little cover for the luggage area. You might also consider taking out as much of the rear seat as you'd feel comfortable parting with; certainly the seat cushion comes right out.
    I'd also add the BT chassis brace and air up the tires as much as possible, within their safe limits.
    That'd be closer to $130-ish (don't recall the current price of the brace).
    And, for an extra $1,000, I'd add the TRD suspension.
  14. BigKahuna13
    BigKahuna13 New Member
    I am impressed already with this board, it's hard to be a newb and usually people say "use the search button" or something else so rude.
    I am digging that shark fin antennae mod but are you sure you measured enough times? :)
  15. dancekat59
    dancekat59 Member
    244
    PRINUS is asking for mods for a "non-hybrid"... not a Prius.
  16. PRINUS
    PRINUS New Member
    <div class='quotetop'>QUOTE(dancekat59 @ Nov 17 2006, 02:40 PM) [snapback]351002[/snapback]</div>
    No Ma'am, I'm looking for info for an '06 PRIUS.
  17. dancekat59
    dancekat59 Member
    244
    Oops! Sorry about that. Looks like you just changed your car from non-hybrid to 2006 Prius.
  18. PRINUS
    PRINUS New Member
    <div class='quotetop'>QUOTE(dancekat59 @ Nov 17 2006, 02:48 PM) [snapback]351006[/snapback]</div>
    I think non-hybrid was the defaut setting. I had 2006 in my sig though.
  19. xr72z
    xr72z New Member
    I heard there is a GP for this shark fin, how do I get on this deal? Any idea what the GP pricing will be?
    <div class='quotetop'>QUOTE(Pinto Girl @ Nov 17 2006, 02:37 PM) [snapback]350997[/snapback]</div>
    PintoGirl, you seem to have some experience with weight saving modifications. Have you done racing in the past or autocrossing?
    Additionally, cutting up your wheel wells recudes the weight drastically. My fabricator said that the pieces of metal taken out for my 22s, weighed in at about 120lbs! :eek: That itself should be a reason to get 22s.
  20. PRINUS
    PRINUS New Member
    <div class='quotetop'>QUOTE(xr72z's prius @ Nov 17 2006, 03:11 PM) [snapback]351026[/snapback]</div>
    Yes Pinotgirl has some great ideas!
    I asked my mechanic about 22 inch wheels and he thought I was crazy! :p
    But I think if possible going even bigger would be best. With the high torque of electric motors, it might be possible to do some good towing with these cars!
