Prius auto shifting into neutral
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ferrond, Jul 22, 2022.
  1. Ferrond
    Ferrond New Member
    Hey Guys,
    So I have a 2008 prius with 110k miles on it. Recently, my car started randomly going into neutral after short commutes. It would most often happen after coming home from work (12 mile commute), and as I go to reverse in the driveway, it would go into neutral. I would then have to hold the shifter in reverse. I notice this happening on hot days- never happened in the early AM when the temperature is still fairly cool.
    I checked the inverter pump, and it had indeed failed, so I replaced it with a new pump and did a drain and fill on the inverter coolant with Super Long Life coolant from Toyota. After replacing the pump the issue went away until we got another heat wave. It's now having the same issue where it throws the prius into neutral, most often at the end of my commute when reversing into my driveway. I checked the inverter pump and it is humming normally and there is turbulence In the reservoir. I bled the coolant thoroughly after replacing the pump and old fluid.
    I only ever had this happen once WHILE driving, and it was because i used the regenerative breaking. I did this assuming it would add load to the inverter, and I wanted to see if the inverter overheating is the culprit to my problem. After a few seconds in B mode at around 50mph, the prius threw itself into neutral. So I assume my problem is the inverter is still overheating?
    The odd thing is, I never once got a check engine light or red triangle of death, even before replacing the failed inverter pump. Not a single warning light. Not sure how to start diagnosing this issue anymore, as from what I can tell, the new inverter pump is working fine.
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    What do think this will do?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,223
    5,907
    Columbia, SC
    I think it's unlikely the two issues (inverter temp and going to neutral are actually related. Maybe more likely a gear shift mechanism issue?
    I've made my inverter overheat by leaving the pump unplugged and then driving on highway at 75mph. Although it codes, it does not shift the car to neutral.
    I've also driven Gen 2s with failed pumps for many miles at 40mph or less and never gotten an overheat trigger.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    Years ago I had read about some Gen2 having problems with the shifter itself on the dash. You have to use a capable scantool to view the data from the hybrid control ecu and see what the shifter is doing.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Use the search forums link up top and search
    shifter goes to neutral
    bunch of posts about it think it’s the shifter mech itself.
