Dealership reco on evap necessary?
Discussion in 'Prius v Main Forum' started by Mabel Cox, Jul 24, 2022.
  1. Mabel Cox
    Mabel Cox New Member
    2015 Prius v wagon
    No warning light but dealership reco’d “evap service” w/o filling in a reason at last regular service appt. Is this necessary? Prius V 2015
  2. Mabel Cox
    2015 Prius v wagon
    Should add 65,000 miles.
  3. bisco
    51,098
    no, how much did they charge you? did they ask for approval?
    Air_Boss likes this.
  4. Mabel Cox
    2015 Prius v wagon
    They asked for approval and I didn’t, assuming it wasn’t needed if there wasn’t a reason. But they’ve just sent me a reminder about it and I thought I’d check with others.
  5. Air_Boss
    Air_Boss Senior Member
    4,136
    1,152
    New Yawk
    Wallet-lightening service…
    bisco and CR94 like this.
  6. bisco
    51,098
    what is reco, reco'd anyway?
  7. Air_Boss
    4,136
    1,152
    New Yawk
    Recommend(ed)
  8. bisco
    51,098
    is that a/c evap?
  9. Air_Boss
    4,136
    1,152
    New Yawk
    Either a/c or fuel?
  10. Mabel Cox
    2015 Prius v wagon
    Sorry, I’m mid-move! It was a/c.
  11. Mabel Cox
    2015 Prius v wagon
    Yes, a/c. Sorry for the delay, I’m mid-move!
  12. bisco
    51,098
    idk what evap service entails. i don't think it is on the maintenance schedule though. some here might feel it's worth checking the freon level after 7 years, but i have never done mine and it's as cold as ice after 10 years.
  13. Air_Boss
    4,136
    1,152
    New Yawk
    If it ain’t broke…
  14. ETC(SS)
    6,932
    Is it in the warranty and maintenance guide's preventative maintenance schedule?
    (Not a rhetorical question, I honestly do not remember.)
    Sounds like the dealership was trying to up-sell you additional maintenance.
    This does not mean that you have a crooked dealership, but it's an 'indicator' and dealership mechanics, politicians, and media all have fairly well established reputations.
    The preventative maintenance schedule in your Warranty and Maintenance guide isn't the end-all be-all for maintaining an almost 8-year-old car, but it's a darned fine place to start - especially if you think that you have to use a dealership for maintenance. I personally find them to be generally very expensive, not very trustworthy, and sometimes not that much more knowledgeable than an honest, independent wrench.
    There are some STARK differences between the maintenance that the CAR SELLER wants you to use, and best practices that have been developed by Prius enthusiasts. I personally think that 10,000 mile oil change intervals are too long for a car with a inadequate oil supply. I also think that some "lifetime" fluids are only good for the lifetime of the warranty.
    MY mileage.
    Yours might vary.
  15. bisco
    51,098
  16. Mendel Leisk
    40,548
    That's the go-to tact with most dealership "service suggestions". There are a few exceptions, say brake fluid and transaxle fluid changes. And Exhaust Gas Recirculation (EGR) and intake manifold cleaning.
    And one that IS in the US schedule, but very subtle: every 3 years or 30K miles you're supposed to do a more in-depth brake service. What that entails is not clearly spelled out. What the schedule does at those intervals, is omit the mention of "visual brake inspection", and add instruction to "Inspect brake linings/drums and brake pads/discs".
  17. Mabel Cox
    2015 Prius v wagon
    Thanks so much, all. So helpful.
