Using these amazon adapters with stock prime charger?
Discussion in 'Prime Plug-in Charging' started by Mavi, Jul 23, 2022.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
  2. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
    i dont think that works althought the 6-50 shape seems to look the same as 5-15 plug.
    The 5-15 plug is smaller that will not fit into the 6-50
    jerrymildred and Salamander_King like this.
  3. BiomedO1
    3,154
    1,668
    SacTown, Ca
    The short answer is NO; it doesn't matter that its UL certified - because your not using it for it's intended purpose. So if you burn down your house - good luck trying to collect from your insurance company or trying to sue the company that created this plug.
    As far as those "permanent adapters"; people are making - they are not permanent. They need to be taken apart every other year, inspected, everything tightened, connections tension checked. Pushing 16A through that adapter, day in and day out will loosen those screw and clip connectors over time. At a minimum; you should hit the connections with an IR temperature gun every 6 months; while its charging the car. Loose connections will heat-up; before failing, arcing, or sparking.
    Hope this helps...
