replace entire strut assembly or just broken spring?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by k1ngn0thing, Jul 23, 2022.
  1. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    one of my struts has a broken spring. ordered a pair of complete assemblies but am now wondering if I should just replace the springs if the struts are still good as the OEMs are probably better than the cheap $50/ea complete assemblies I ordered.
  2. PriusCamper
    PriusCamper Senior Member
    13,006
    5,287
    Pacific Northwest, USA
    Got a link to what you ordered? Sometimes those cheap ones are fairly high quality...
  3. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
  4. Tombukt2
    13,336
    2,401
    With the looks of that spring I would say get a new strut too so when you say $50 strut you mean just the cartridge no spring no top plate go to an $80 strut or $100 strut like I don't know gas rider from KYB or something along those lines. And then with your spring you sourced and an upper mount and let it rip looks like a lot of miles and a bit of rust
  5. PriusCamper
    13,006
    5,287
    See link above... These are the cheap ebay ones that we talked about before. It's a complete assembly so no sketchy spring loading and they only cost about $100 per pair. You might remember that the ones I bought for the rear of my Prius were slightly off on the plate mounting angle and didn't fit. So I got my money back and bought a different pair that I've yet to install.
  6. Tombukt2
    13,336
    2,401
    I'd give a set of four of those a world no problem on my '09 should be just fine matter of fact it's time to do the '09 so any minute I'll be ordering because they're getting loud and clunky and pretty noisy 290,000
  7. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    That spring perch doesn't look all that robust, how many miles on that rear OEM strut?
    If you're feel frisky, you can swap a new perch/spring onto that crusty OEM, though the rest of that strut looks pretty jacked up as well.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Many people do not have the tools needed to safely compress a spring while removing and reinstalling the strut assembly.
    PriusCamper likes this.
  9. PriusCamper
    13,006
    5,287
    Agreed, nothing safe about about DIY spring loading onto struts...
  10. Tombukt2
    13,336
    2,401
    You undo the nut on both sides while the strut is kind of still attached and has the weight of the car on it then when you jack it up but just comes undone that's really easy to do and it doesn't create really any problems that nobody can get killed see the videos online of people who have blasted nut off without any thing on the spring No one's been killed and I don't think seriously hurt it's not like a truck tire blowing up outside of the cage. But anyway enjoy and be safe Big thick panduit straps can work too easily done it many times
  11. BiomedO1
    4,059
    2,136
    SacTown, Ca
    IMHO; I wouldn't risk injury or damage to my car by trying to save a few bucks. Just replace the entire assembly. The link you posted has a lifetime warranty, so your covered there. Hopefully it'll handle as well as the OEM. I'm partial to KYB or OEM strut assemblies, mainly because I find that aftermarket ones tend to be too soft for my liking.
    Good Luck.
  12. mr_guy_mann
    4,083
    1,995
    NJ-USA
    Hell no!
    A strut coil spring has a huge amount of energy when compressed. For every youtube video where someone does a (stupid) shortcut like "jacking" a spring in or out - and it works, there's 2 or 3 showing the fails. And the ones that go really bad don't have videos, they have short news articles - maybe in the obituaries.
    Do what you want, but don't suggest that it's even remotely a good idea to anyone else.
  13. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    idk when/if the previous owner replaced them, but I've had it for about 60k miles/5years.car has 278k on it. not going to chance anything and will just have the new complete assemblies installed.
    #13 k1ngn0thing, Jul 24, 2022
