Back in the saddle.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Jul 27, 2022.
  1. Prius92
    Prius92 Active Member
    592
    121
    Iowa
    Got my new discharger today, after accidentally reversing polarity and blowing up the old one.
    Here's another module that was taken all the way down to 3 volts, and trickle charged at .5A all night.
    Almost 5000MAH capacity, pretty darn good for 14 year old modules with almost 190k miles on them.
    This line is what you want to see, as you can see the voltage quickly drops at first as the excess charge beyond what the nominal voltage is bled off, followed by a smooth downward trend, and once it reaches the bottom of the nominal voltage, a sharp decline to 6 volts.
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    12,645
    5,108
    Pacific Northwest, USA
    Interesting that you discharge didn't have a reverse polarity alarm? I mean I have fried a hobby charge once because I had headphones on and didn't hear the alarm... But @fach took it home and found the component it needed and repaired it.
    Anyways, I'd love to have a discharger that gives such a nice looking graph like that. Can you share a link to what you bought and how much?
  3. Prius92
    592
    121
    Iowa
    This is what I bought: https://www.ebay.com/itm/333626507045
    You may find some cheaper, but that had the fastest shipping (UPS).
    Nice thing about it...it can do 3 modules at once, very nice for discharging multiple modules at once.
    Only bad thing about it..it runs off the modules..and cuts out around 5.4V. So you have to use a hobby charger to take each module down to 3 volts.
    When it blew, one of the components blew smoke, and charred the top of the component, so no way of knowing what value I need, all I know is that it was a triac.
    My hobby charger alerts to reverse polarity, but not this. It's supposed to blow a fuse, which it did, a 40A one at that, but still ended up blowing a component. So I double check the wires before hooking up.
  4. PriusCamper
    12,645
    5,108
    Wow... So glad SkyRC finally made a quality discharger like this. I might buy more than one!
    What kind of Operating System does the data port require? Windows? Apple? Linux? Sure hope I can get it to run on Linux!
  5. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    Good thing I didn't buy the SkyRC discharger In Jan 22, was $129, price is better on Ebay for $89.
    SkyRC Battery Discharger suitable for Prius Modules? | PriusChat
    Classic SysAdmin: How to Install and Use Wine to Run Windows Applications on Linux - Linux Foundation
    Easily run Windows software on Linux with Bottles! ⋅ Bottles (usebottles.com)
    SFO and PriusCamper like this.
  6. Prius92
    592
    121
    Iowa
    I am debating if a module tests to at least 4,000MAh if there is any point in running another discharge cycle? That's 60 percent capacity.
  7. PriusCamper
    12,645
    5,108
    Inexpensive equipment like this isn't going to give an accurate measurement... Just use the best modules as best as you can tell.
  8. Prius92
    592
    121
    Iowa
    Here is the numbers so far from today's discharging, prior numbers are after the modules were discharged/charged TWICE down to 6 volts.
    2163-4728
    4009-4643
    2204-4406
    2190-4013
    2756-4020.
    As you can see there is a clear benefit to discharging down to 3 volts.
  9. PriusCamper
    12,645
    5,108
    Yeah, back then I didn't know this discharger sent the data to a computer so you could have a chart of each modules discharge health. I think when you shared it back then I thought it was a 250w charger, not a discharger, so my opinion of it was flawed. But now I look forward to getting one of these!
    alftoy likes this.
  10. Prius92
    592
    121
    Iowa
    Last module just discharged at 5007MAh!
    Here's a shot of the work in progress, using a .61A current load to discharge each module to 3 volts. Yes, they won't be even when done, but I can then use the hobby charger to evenly discharge them. This just heavily speeds things up.
