Car wouldn't start
Discussion in 'Prime Main Forum (2017-2022)' started by snarfu, Jul 27, 2022.
  1. bisco
    51,829
    did you check the negative cable to ground connection?
    look at the cabin filter for rodent signs
  2. snarfu
    snarfu Junior Member
    Pennsylvania
    How did it get hit by an emp? Was it able to recover to act normal after or did it stay dead until it was repaired?
  3. snarfu
    Pennsylvania
    Dealer said no signs of rodents. I didn't check the ground cable, but presume they did. The tech has a prius and is supposed to be very knowledgeable about them.
  4. BiomedO1
    3,449
    1,795
    SacTown, Ca
    The battery clamps expand and contract in the heat & cold. A loose battery clamp on either terminal will pass voltage; but when it comes to drawing amperage - that's where the surface area contact of the battery terminals come into play.
    Us old timers, probably seen a battery terminal spark, while trying to turn-over an old V8 engine. Take off the old terminals, clean, re-tighten and the car will fire right up.
  5. snarfu
    Pennsylvania
    Update but not really...
    Dealer had it about a week but it didn't replicate the issue (they put about 1 1/2 miles on it). Toyota wouldn't open a case because it wasn't actively having the issue.
    Took the car on a 1000 mile trip last week and it hasn't repeated the issue. Still think there is a faulty memory somewhere in the computer.
    Salamander_King and bisco like this.
  6. bisco
    51,829
    prius is a rolling computer, and there are a lot of ecu's. could a glitch be possible? i think so.
    maybe when you put the noco on it, it was the solution
  7. snarfu
    Pennsylvania
    The thing that corrected it was disconnecting the ecu and reconnecting it
    bisco and Marine Ray like this.
  8. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    How do you disconnect/reconnect the ECU ?
  9. Salamander_King
    Salamander_King Senior Member
    11,015
    8,943
    New England
    From reading the OP's previous comments, I suspect that was what was done at the dealer. I am sure you can DIY, but it may involve removing the dash panel and other critical knowledge of the car's electronics. I would not try it myself
    Marine Ray likes this.
  10. Gokhan
    Gokhan Senior Member
    6,128
    2,428
    Paramount CA
    Stalled car
    Three engineers were riding in a car: a mechanical engineer, a chemical engineer, and a Microsoft software engineer. The car stalled, and they rolled it to the side of the road.
    The mechanical engineer popped the hood, looked in and said "Look. The drive belt is loose. All we have to do is tighten it up and the car will work just fine."
    The chemical engineer replied "No, that's all wrong. The problem is fuel contamination. We have to drain the fuel, filter it, and then everything will be A-OK."
    The Microsoft software engineer told the other two "No, I've seen this problem before. We have to get back in the car, close all the windows, shut down the car, get out, get back in, start up the car, open all the windows, and then it will run."
    Marine Ray and Salamander_King like this.
  11. Trollbait
    12,497
    Or it could as simple as disconnecting the 12V battery for a bit, with even trying to start the car to discharge any latent electricity.
    Salamander_King likes this.
  12. Salamander_King
    11,015
    8,943
    New England
    Yeah, that trick may have worked. I don't think the OP tried it. It is possible that is exactly what the dealer did, but we don't know.
  13. bisco
    51,829
    maybe there was corrosion on the pins, and that scraped them off a bit. the mechanical or chemical engineers might know
    2010moneypit? and Gokhan like this.
