cruise control not available
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Gas Mizer, Jul 12, 2020.
  1. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    tl;dr I was going down the road and the drcc kicked off and the error message, "cruise control not available", came up. I cleaned the emblem and disconnected the battery hoping it would reset the ecu, and the problem persists. Standard cruise works fine.
    Car history: The a/c went out a couple of months ago with 50k miles and I took it to a local hybrid shop. The guy told me he hooked their diagnostics up to the car and it was doing odd things to his scanner. He blamed my audio system that I have installed. Then he said he tested the 12v battery and it wasn't charging. After replacing it they hooked the scanner back up and it worked fine and he said he couldn't find anything wrong. He tested the electrical system to see if there was draw on the battery with the car off (testing the audio system install I guess) and said that was fine as well. So they put dye in the a/c. Lo and behold the condensor had a crack in it. They replaced the condensor, charged the a/c and returned the car. Everything was working fine. Even went on a 5 hour road trip. Then driving down the road with the cruise on, the car decelerates and that message popped up with a big orangish triangle. Turning the cruise off and turning it back on gets rid of the message and the triangle, but comes right back on successive attempts. I hooked up my Carista to it and the only thing I could find other than "No fault codes" or "No ECU present" was this:
    Heater & air conditioning
    Part # suffix: 47520
    Fault codes:
    U0163 Lost Communication With Navigation Control Module
    I'm not seeing an option to reset codes with the Carista.
  2. krmcg
    2,592
    2,392
    Whittier, CA
    The first thing to do to help eliminate causes is to check the voltage in your new 12 volt battery. So many issues that arise can be traced back to that battery being undercharged.
  3. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Looks like it's at 12.6v car off. 13.6v car on.
  4. krmcg
    2,592
    2,392
    Whittier, CA
    Is the 12.6v just after you turned the car off? You will need to test it after it sits (overnight of so) to see if the charge holds. This opens up a can of worms because you have to test the battery without "waking" the car. So, if possible unlatch the hood the night before and check the battery in the morning without your key fob close enough that the car recognizes it. That will provide the most reliable results.
  5. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    That was after the car had been sitting for 3 hours. I did unlock the car to open the hood however. I wouldn't think it would make that big of a difference?
  6. krmcg
    2,592
    2,392
    Whittier, CA
    It seems to. Don't really know why or how, but I've seen it mentioned on this site dozens of times...
  7. ChapmanF
    18,455
    Yes ... "mentioned". "Mentioned" so often it drags other people into "mentioning" it too, even when they "don't really know why or how" any more than any of the earlier mentioners do.
    12.6 is not the explanation of your DRCC question. The car's computers can tell you their reasons for saying DRCC is not available, and then you can follow up with the associated troubleshooting procedures and find out why that is.
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    I've never heard/seen DRCC malfunction because of a 12v battery problem. Most likely the emblem is dirty and needs cleaning, or something struck the emblem/front end causing the radar dish to misalign or become damaged.
  9. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Emblem is spotless and I haven't hit anything (to my knowledge).
  10. SLC1HobeSound
    SLC1HobeSound New Member
    Hobe Sound FL
