2008 with 190k. I downloaded Dr Prius app because I only get 32 mpg. What exactly am I looking for?
Discussion in 'Gen 2 Prius Fuel Economy' started by Gilberto, Aug 1, 2022.
  1. Gilberto
    Gilberto New Member
    merced ca us
    01D9B455-4680-453B-A3F9-FF6D1631E064.png 35E22148-BCC3-4B2C-A79A-22F982C3F458.png 7D826FD4-F6FB-46D2-BF1A-8A8B21BB7A1B.png 24DB44BD-C6CB-43D6-AE94-6837194D747C.png E7457D1B-06BE-4176-9132-77D0AF5E68BA.png
    I have kept up with maintenance, oil, filters, tire pressures, battery fan cleaning, spark plugs you name it. but i still get only 32 mpg. where this same time last year it was 42
    51,259
    isn't there a health check with percentage of life remaining?
    any changes to your car or driving? tires? brakes? trip length? topography?
    have you cleaned the throttle body and maf? does she burn any oil?
  3. Gilberto
    Gilberto New Member
    merced ca us
    yes there is a health check i don’t know why it didn’t upload. it said 47.59% and “WELL DONE. Battery pack has estimated 47.59% capacity left, it is in bad condition but will still run.” but it has never given a check engine light or anything
    i haven’t changed anything in my driving i am a pizza delivery driver and have been for more than a year
    i have not cleaned throttle body or maf, and it burns about half a quart every 3000 miles
  4. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    The Internal Resistance is getting high at 29 but not unexpected with a 50% life left. A cell rebalancing may help. You can DIY or get local shop to do it.
    At 190k, have the plugs ever been changed?
    Also check the PCV valve. If it’s sticking may cause problems and it’s a cheap part.
    Have you changed the serpentine belt? If not get that changed or DIY.
    At 190k the car is still an adolescent so may last you another 100k.
