Bought a 2015 Prius Three
Discussion in 'Newbie Forum' started by SPX, Aug 1, 2022.
  1. SPX
    SPX New Member
    Simpsonville, SC
    Hi everyone,
    New Prius owner here. I bought a 2015 Prius Three with 197k miles from a Toyota dealership. Had a Ford Focus but can't get parts for it - google Focus transmission problems if you're interested. Any way, hope the Prius is as reliable as their reputation. Any advice for a new owner?
    mikey_t and bisco like this.
    51,854
    congrats and welcome!
    15 is the best year gen 3 due to updated pistons and rings.
    if you are a diy'er, dig right into the maintenance schedule and clean the egr circuit.
    all the best!
    Mendel Leisk and mikey_t like this.
  3. Mendel Leisk
    41,355
    For EGR (Exhaust Gas Recirculation) see first link in my signature.
    (if on a phone hold it landscape orientation to see signatures)
  4. SPX
    SPX New Member
    Simpsonville, SC
    Thank you bisco and Mendel. Clean the EGR first. What else should be a priority?
    So far I'm getting about 41mpg on my commute to work. Most of that is on the freeway which can be stop and go like the city in the Greenville/Spartanburg area - I blame the short on off ramps.
    So a couple of cons. I am not good at buying cars so I don't find these things until after the purchase.
    1. No auto headlights. I thought that would be a given.
    2. The lock beep. Most cars you can turn off the beep when you lock and unlock the car but I could not find that feature on the Prius.
    I will go through your list Mendel but I doubt that I am going to buy snow tires for winter driving in
    South Carolina. One can only hope for that much snow,
    Oh yeah, and 3. The slow acceleration. I am having to learn to choose when I pull into traffic or merge more carefully.
    Thanks again for the replies.
  5. bisco
    51,854
    tranny fluid (it's not on the maintenance schedule, toyota calls it lifetime.
    if you don't know the maintenance history (you can check at toyota.com/owners and get a maintenance schedule there as well, if you don't have one.
    clean the throttle body and maf
    replace all fluids
    get a free 12v load test at an auto parts store
    learn where the 12v battery is, the jump point under the hood and the emergency release inside the hatch door.
    make sure you have tow completely working fobs, and test the maechanical keys in the drivers door lock.
    tyres pressure, bump up a bit over door jamb spec
    cabin and air filters check/clean/replace
    follow the maintenance schedule, repeating at the end of the highest mileage in the schedule
    mikey_t likes this.
  6. nicoj36
    nicoj36 Active Member
    518
    162
    Definitely clean egr. Search NutzAboutBolts on youtube for the diy videos. Give it a bottle of fuel treatment as well.
    mikey_t likes this.
  7. SPX
    SPX New Member
    Simpsonville, SC
    Thanks again everyone. Looks like I have my work cut out for me. I'll buy some fuel treatment this weekend.
    I have one key fob and have tested the manual key.
    Where is the best place to buy additional key sets?
    Also a confession. I came home from work and went to bed and my sister found my car running. It had ran for a few hours. So now I know. Foot off the brake and press the button while in park. Has anyone else done this?
  8. Mendel Leisk
    41,355
    Any time the cArs on and you push the power button, it should go into park and shut off, regardless of where your feet are. :coffee:
  9. SPX
    SPX New Member
    Simpsonville, SC
    Thanks Mendel. That works perfect.
