Can't shut off backup beep.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 8, 2022.
  1. Prius92
    Prius92 Active Member
    567
    116
    Iowa
    This was a while ago but wonder why. Tried the non-techy way of doing it using the trip button like I've seen on YT.
    Took it Toyota and they couldn't even turn it off with a tech stream. They told me they've had issues disabling the beep in some Gen 2's.
    Also..why on earth did Toyota even put a backup beeper in these cars? Would make sense if it was on the outside where people can't hear the ICE if it's off..but it's pointless on the inside.
  2. Tombukt2
    12,349
    2,183
    Find beeper cut wire or post if board mounted.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    There is no option for turning it off. You can only choose between a single beep and continuous beeping.
  4. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
    How does one switch to single beep?
  5. PriusCamper
    PriusCamper Senior Member
    12,139
    4,924
    Pacific Northwest, USA
    That's true with newer Prius. But old Gen2 Prius you can turn them off entirely. Catch is sooner or later you're gonna stop at a red light a little over the limit line and put it in reverse to back up a little and without that beep you may forget to shift back into drive. If you're a leadfooted driver that likes to accelerate quickly you're gonna smash into the vehicle behind you. But if you're a careful driver with a quick reaction time you might get away with it.
    jerrymildred likes this.
  6. bisco
    51,259
    never heard of a trip meter button reverse beep control. carista used to be a popular one
  7. alftoy
    alftoy Senior Member
    1,132
    515
    Saskatchewan, Canada
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,980
    1,926
    NJ-USA
    The Dr Prius app shows "disable reverse beep" option in the Special Features screen.
  9. Another
    1,818
    515
    Naples, Florida
    The Dr Prius feature is bogus. It doesn’t work on many Prius’s.
    When I tried to use it on my 2007, it said, sorry doesn’t work with your model.
  10. jerrymildred
    11,517
    14,137
    Tampa, FL
    I just found a video showing how that's done. I sure wish I'd known that when we had our Gen 2 Prii.
    From 1972 through 2014 none of my cars had reverse beepers. Somehow I miraculously escaped flooring the accelerator without knowing what gear I was in. At least when that gear was in reverse anyway. LOL!
