To replace the entire engine, or not to replace the entire engine, that is the question?
Discussion in 'Prius v Technical Discussion' started by Lillian Miller, Aug 10, 2022.
  1. Lillian Miller
    Lillian Miller New Member
    Atlanta, GA
    My 2012 Prius V with about 95,000 miles, started have an issue about a year ago. While I was driving on the highway for about 2 hours, my check oil level light and overheating light came onto the dashboard. I had just had an oil change about 2 months prior. I pulled over to an auto zone, and they helped me figure out I had 0 oil!! I put some in, but I continued to have the overheat sign coming up. I took it to the Toyota dealership, and the diagnosed it as having "engine consuming oil. internally 90il getting past piston rings and into combustion chamber. Recommenced replacing engine assembly ($6500) or rebuild existing engine ($6500). I asked if I could still drive it, and they said yes as long as I get the very best oil. So fast forward to now. It's my daughter's car, and she drives it for about 10 mins on the highway everyday. It now shows the overheating light on the dashboard everyday. It has tons of oil. I have already replaced the IPM transistor and the replace the brake master cylinder and booster. This Prius feels like a constant money pit!!! Should I replace the engine? If so, what else could break down and cost me significant money? The hybrid battery? I am just wondering if I should continue to throw money into it since it has low miles, or trade it in for a different car?
  2. rjparker
    9,756
    6,014
    It sounds like you need a used or a rebuilt engine. If it were me, it would be a used engine that was rebuilt. I would not rebuild your engine since it ran out of oil and is overheating.
    A simple engine swap with an unrebuilt used engine would be less money but is likely to have the same oil consumption problem sooner or later.
    This is not entirely your fault. The 2010-2014 Prius engines from the factory often fail with oil consumption, head gasket issues or overheating. Toyota actually fixed the engines free under the 5 year 60,000 mile powertrain warranty because THEY KNEW their design was flawed. When you get it fixed, go with 5,000 mile oil changes rather than the recommended 10,000 mile changes.
    You will hear others say "clean the egr" blah blah blah. It won't help. Ensure all the egr and intake manifold parts are cleaned well when they rebuild your new to you used engine.
    There is a good chance your hybrid battery will fail in the next couple of years. So if you are financially strong right now and can afford a total loss as a trade in, while paying a premium for a new or recent used car, then go that way. Most can't justify it right now so major repairs are more common. If you trade the car the dealer will simply auction it off giving you maybe $500 in real value, regardless of what they say.
    Finally, ask around for a quality independent shop. Some can do the engine for $3,500-$5,000.
  3. Mendel Leisk
    40,828
    You could do a short block replacement. I believe it’s everything between cylinder head and the lower split line in the block. It has the cylinder bores, crankshaft, pistons.
    They’re around $2~3k new, and rebuilt may be available for significantly less. Not sure what the labour would be on that; if $3500 guess you’re back where you started: around $6500. But you’ve got brand new.
    And hopefully it’s the revised pistons/rings, not sure how to verify that. You’d think that’s all Toyota would be using, after the low-tension piston ring fiasco.
    I think a Prius v short block, and even a full engine, will be identical to 3rd gen Prius; the differences are only in the transaxle.
    #3 Mendel Leisk, Aug 11, 2022
  4. Tim Jones
    Tim Jones Senior Member
    1,751
    562
    SE Texas
    2011 Nissan LEAF
    Put a stick of dynomite in it...................... it will only be more $$$$$$$$$$$$ thousands of dollars next...
  5. bisco
    51,370
    how do you know that whoever changed the oil didn't tighten the drain plug fully, or use a washer to seal it?
    how many miles did it go from the oil change to the problem?
  6. mikefocke
    3,921
    1,768
    Sanford, NC
    Did only one engine replacement. 2k later I was back for another under warranty. Not a Toyota but an example of what can go wrong.
    How much do you trust the rebuilder (mine was a national rebuilder) and the assembler?
