2019 Prius Emissions Information?
Discussion in 'Gen 4 Prius Main Forum' started by treet007, Aug 12, 2022.
Tags:
  1. treet007
    treet007 Member
    102
    Ireland
    2019 Prius
    Hi there. I am looking for the NOx (nitrogen) emissions information for a 2019 Prius Luxury model. This is for Ireland/European market. I know the CO2 (carbon dioxide) emissions is 84 g/km (gram/kilometer). However, I cannot find the NOx.
    Engine capacity size for this particular Prius model is 1798 cm(3) (cubic centimeter).
    Thanks. --George
    52,258
    is there a euro equivalent to the epa?
  3. treet007
    treet007 Member
    102
    Ireland
    2019 Prius
    Yes and no. This is the main website: European Environment Agency's home page — European Environment Agency
    The issue is that the site is not searchable for vehicle-type information. I have been searching this and other sources but so far no luck.
    Attached is my registration info that I receive for my vehicle. I blotted out private info. The NOx is not listed.
    BTW, the reason why I need the info is to register the vehicle to Revenue.ie for tax credit. You would think they have a database (or a link to one), but strangely not.
    --George
  4. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Summary:
    Toyota Prius Plug-In Hybrid (2017 to present)
    Engine: 1.8 Plug-in hybrid (Euro 6b)
    Measured emissions: NOx (0.004g/km), CO (0.025g/km), CO2 (58g/km)
    More Info:
    Code:
    Some links:
    https://www.google.com/search?q=2019+Prius+"Nox"
    https://www.which.co.uk/reviews/new-and-used-cars/article/car-emissions/low-emission-cars-aS2iB6E0PQeK
    https://global.toyota/en/newsroom/toyota/26339688.html
    Oct. 15, 1997
    Toyota to Unveil the Prius Hybrid Car
    Prius
    This innovative sedan is equipped with the Toyota Hybrid System and has been developed under the "harmonious vehicle" theme to make it fitting for the approaching twenty-first century.
    Prius was developed in response to global environmental concerns.
    Fuel consumption of 28km/L (Japan 10.15 mode) is double that of a conventional vehicle in the same class, CO2 emissions are halved, and CO, HC, and NOx emissions are 1/10th of statutory requirements.
    https://www.nextgreencar.com/emissions/make-model/toyota/
    https://www.nextgreencar.com/emissions/make-model/toyota/prius/
    https://www.nextgreencar.com/view-car/70655/prius/
    Note, mg/km shown, not g/km.  So, 6mg/km is that 0.06g/km.
    https://autocatalogarchive.com/wp-content/uploads/2020/08/Toyota-Prius-PHEV-2019-UK.pdf
    ENVIRONMENTAL PERFORMANCE 1.8 Plug-in Petrol Hybrid (122 hp)
    Automatic
    Fuel consumption (WLTP)
    Combined driving (mpg) 217.3
    Fuel grade – recommended 95 or more
    Fuel tank capacity (l) 43
    Carbon dioxide, CO (NEDC equivalent)
    Combined driving (g/km) 29
    Exhaust emissions (regulation EC/715/2007 as amended by EC 2016/646W)
    Euro class EURO 6 DG
    Carbon Monoxide, CO (mg/km) 28.3
    Hydrocarbons, THC (mg/km) 5.1
    Hydrocarbons, NMHC (mg/km) 4.7
    Nitrogen Oxides, NOx (mg/km) 3.7
    Sound level drive by (dB(A)) 67
    ENGINE 1.8 Plug-in Petrol Hybrid (122 hp)
    Automatic
    Engine code 2ZR-FXE
    Number of cylinders 4, in line
    Valve mechanism 16-valve DOHC, chain drive (with VVT-i)
    Fuel injection system SFI
    Displacement (cc) 1798
    Bore x stroke (mm x mm) 80.5 x 88.3
    Compression ratio 13.0:1
    Maximum torque (Nm@rpm) 142/3600
    Electric front motor: type Permanent magnet, synchronous motor
    Figures are provided for comparative purposes; only compare fuel consumption and CO figures with other cars tested to the same technical procedures. These figures may not reflect real-life
    driving results. All models and grades are certified according to the World Harmonised Light Vehicle Test Procedure (WLTP), which replaces the New European Driving Cycle test procedure (NEDC).
    All CO figures quoted are NEDC equivalent. All mpg figures quoted are WLTP figures.
    https://www.researchgate.net/publication/351454596_Real-world_particle_and_NOx_emissions_from_hybrid_electric_vehicles_under_cold_weather_conditions
    https://www.researchgate.net/figure/Correlations-between-relative-emission-factors-of-a-CO2-b-NOX-and-c-THC-and-average_fig1_277324159
    Imho, on to the much more important topic. :)
    North Carolina seceded from America and became part of Ireland?
    I knew "The North" should've blanked bombed and nuked "The South" back in the civil war. ;-)
    Btw:
    seceded: past tense of secession
    secession: the action of withdrawing formally from membership of a federation or body, especially a political state.
    "the republics want secession from the union"
    secession: In America, what self-serving politicians, and brain-dead idiots talk about.
    For example:
    Code:
    https://www.axios.com/2022/08/09/southern-california-county-voters-secession-measure
    Note, except for New England Independence Campaign! :)
    https://www.newenglandindependence.org/
    Welcome to New England!
    The New England Independence Campaign (NEIC) is a group of individuals throughout New England who have come together to promote the idea of independence for our nation. We aim to achieve this peacefully, through education and the ballot box. Our members encompass a wide range of the political spectrum. We welcome all New Englanders to join our movement.
    Note to all Non-New Englanders - Stay the ******* out of our Country! :D
    Good Luck!
