What fuel economy can I expect?
Discussion in 'Gen 2 Prius Fuel Economy' started by wanmichael, Nov 18, 2006.
  1. wanmichael
    wanmichael New Member
    Sacramento
    All,
    I'm trying to decide between a '07 Prius or a '07 HCH II. Eventually, if and when I decide to purchase next spring, the cost difference between the Prius and HCH II will be about $2k after all available tax credits. I gather that the two will deliver similar efficiency under my type of service.
    The type of service the vehicle will see, is:
    ~70% 1-2 mi trips
    ~30% 5-10 mi trips, city/hwy mix.
    Current vehicle is a 96 Saturn SL2 Auto, which delivers between 24-27 mpg in this type of service.
    With the Prius, can I expect to obtain 35-40 mpg over the life of the vehicle throughout all seasons? Or more? Does anyone here have a similar driving profile?
    Thanks in advance for any help.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Are the 1-2 mile trips multiple trips...IOW, are going 1 mile to one store, stop for 10 minutes, then on to the next, etc. Or, are they 1 mile to work, car sits all day, then 1 mile home?
    The 1-2 mile trips are definately killers unless you do multiple in a row. In Sacramento the weather should help matters. I suspect you'll see closer to 45mpg lifetime depending upon your driving style, traffic conditions, what speed the roadways you drive on tend to be, etc. But it's pretty rare to see someone getting under 45mpg lifetime if they try at all to get good FE.
  3. wanmichael
    Sacramento
    Only the 5-10 mi city/hwy trips, which make-up about 30% (I'm guessing), will be in a row.
    The 1-2 mi trips will be spaced at least an hr apart. The engine doesn't get very warm in the first place, so its probably not much better than a completely cold start.
  4. berylrb
    berylrb Member
    308
    san francisco?
    <div class='quotetop'>QUOTE(SodaGuy @ Nov 18 2006, 09:56 PM) [snapback]351560[/snapback]</div>
    Hey Soda Guy,
    We used to live in Sacramento and we maintain homes in Elk Grove (Sacramento suburb), so we go at least once/quarter, as well as visit family and vacation in Sacramento Old Town/Mid Town.
    Efusco is right on target! Checking my spreadsheet there were multiple day trips to Elk Grove where i refilled in Elk Grove, and mileage was 42-44 easily. All of those trips were drive 1-2 miles stop for an hour, drive again. Elk Grove streets are pretty typical of Sacramento (Although not Fair Oaks or Carmichael).
    Compare that to our SF 1-2 mile stop for an hour, drive again which yielded about 36 mpg average this past September about 55 F average over three tanks. The only way for me to see 40 under this type of drivng is to get out of town, LOL.
    Hence, again Efusco's 45 mpg for Sacramento is in the ballpark from my personal real world experience. In the summer and spring you should easily be approaching 50 mpg.
  5. Cheap!
    Cheap! New Member
    1,157
    Your mileage will improve some after about a 2000 mi brake-in period so don’t get disappointed at first. Also, like most drivers you have to learn how to drive it for the best mileage. Don’t gun it at red lights and don’t drive like an old person either, as both will kill you mileage. Set you tires for the max safe presure and soon you will get the hang of it.
  6. wanmichael
    Sacramento
    <div class='quotetop'>QUOTE(berylrb @ Nov 19 2006, 08:19 AM) [snapback]351690[/snapback]</div>
    I take that you were in the Laguna area? I'm over here in the Greenhaven/Pocket area, so it may be a bit different. Hopefully I'll be able to obtain similar mileage if and when I get one.
    Why does SF driving yield less fuel economy? Is it due to the hilly terrain, which is a strain on the small sized engine?
  7. efusco
    19,891
    1,196
    Nixa, MO
    Hills are a strain on any size engine, but yes, the hills would be the problem.
  8. wanmichael
    Sacramento
    I see. I just did a quick little comparison, for my conditions, between the HCHII and Prius:
    Here are my figures:
    Vehicle price (before TTL):
    Civic EX, Automatic- $19k
    Prius, $24k (after tax credit)
    HCHII, $21k (after tax credit)
    (Apparently, my earlier math was off...the difference was much more than that. )
    Projected Fuel Economy:
    Civic EX, 27 mpg
    Prius, 38 mpg
    HCHII, 38 mpg
    Projected Fuel Costs @ $3.00/gal, over 150k miles:
    Civic EX- $16,666.67
    Prius- $11,842.11
    HCH II- $11,842.11
    Fuel Savings vs. Additional cost of vehicle:
    Prius- $4824.56 vs. $5k
    HCHII- $4824.56 vs. $3k
    So, I'll questionably, barely break even with the Prius, but for sure with the HCHII with my "optimistic" fuel economy predictions.
  9. efusco
    19,891
    1,196
    Nixa, MO
    Why did you use 38mpg for Prius? Not that $45 will make a huge difference in the cost differential, but certainly is a more realistic number.
    Also, don't get caught in the trap of just looking at cost/fuel savings. Prius offers lower emissions, arguably better performance and reliability, hatch-back which is very nice for storage/convenience.
    Buying a new vehicle is not an investment, it is a way to lose money to start with. Consider all the factors of the vehicle, test drive them, compare features, etc. A couple hundred or even a couple thousand dollars won't be an issue if you don't feel satisfied with the product.
    Oops, I meant 45mpg, not $45.
  10. wanmichael
    Sacramento
    I was trying to predict worse case scenario...I was formerly using 35 (yikes!) but I figured 38 should be a bit more realistic.
    I agree the Prius will be more reliable. Toyota's CVT has been outstanding compared to Honda's.
  11. efusco
    19,891
    1,196
    Nixa, MO
    Honestly, I think 45 is realistic...you've really got to be abusive and in terrible conditions to get worse.
  12. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    AND, if you get that HCH thingy...you will have to go over to "that other board". We would all miss you!!!!
  13. berylrb
    berylrb Member
    308
    san francisco?
    <div class='quotetop'>QUOTE(SodaGuy @ Nov 19 2006, 03:48 PM) [snapback]351775[/snapback]</div>
    I'd have to agree with Efusco here SodaGuy, your really conservative with 38 mpg. I know the Pocket area and Land Park very well, you could drive in your sleep and get 45 mpg! I go to your Home Depot all the time, less crowded than Elk Grove.
    Yep, SF is not just hilly but we don't have the opportunity to have space to pulse and glide, but our biggest problem is that as a family we are bright green, using Muni transportation as much as possible, it isn't unusual to go a whole tank on just 2 mile trips to Safeway, OUCH, impressively greenish but ouch. It's not unusual to get to Safeway and not even register a 5 minute bar! Ouch again!
  14. BobA
    BobA New Member
    731
    Denver CO
    I've got a 2004 with only 12,500 miles... I'm not a big driver.. to the store and other short trips... my last four tanks have been over 52 mpg.. but it has taken the mileage to break into that.. I have never gotten worse than 47mpg from day one.. I live in the Denver area and it does get cold here.. cold I have found does bring the MPG down.. the Honda owners around here that I have talked to are only getting about 40 mpg..
    I do notice the media has to report that the Prius only gets about 40 mpg.. they did a stort on the 'Smart' the other night saying that it scored a very bad grade.. although it only got 40 mpg.. it lacked the room of a Prius which got about the same mileage.. grrrrrr ... prompted an e-mail to the news guy..
  15. Paul R. Haller
    285
    43
    Walnut Creek
    I bought an 06 in August. My first 3 tankfulls I averaged 48 MPG. Now, with winter fuel, I'm averaging just over 40 MPG. Kind of disappointing but my wife who has an 05 gets slightly better mileage. She gets just about 52 in summer and 45 in winter but she has a different commute then I. She drives from Walnut Creek to Hayward each day as a grammer school principal. I commute from Walnut Creek to Cal Berkeley each day and I use Fish Ranch Road to avoid the tube but that means a 1700 ft climb up and over the Berkeley hills twice a day, so I average slightly less mileage then she.
    I would also agree With efusco and others here. In Sac. you should see, after some miles are on the car, at least 45 in summer and 40+ in winter. I'd like to comment on another topic that is related to this thread. It would seem that we Californians get slightly less mileage then others on this site that live elsewhere. I can only conclude that our gas has more additives that reduce fuel economy for cleaner air or, and I think this unlikely, we as a group are not as good at saving gas as others here.
    :p :p
    -Paul R. Haller-
  16. berylrb
    berylrb Member
    308
    san francisco?
    <div class='quotetop'>QUOTE(Paul R. Haller @ Nov 20 2006, 02:46 AM) [snapback]352000[/snapback]</div>
    Interesting theory Paul! However, I have driven in Atlanta, Clinton, New Jersey and Chicago and have noticed similar traffic patterns everywhere, although the only place that even comes close to the Berkeley/Bay Bridge/San Francisco corridor is New York City!
    However Two, my best mileage ever was 2004 Memorial Day Weekend, a round trip from SF to Sacramento one tank 67 mpg and that was at 7704 miles on the odometer. Here's some other bests:
    • 54 mpg, 313 miles one tank, in and around Elk Grove 5/30-6/14/04, 9063 miles on the odo
    • 45 mpg, 1449 miles on 5 tanks, SF to San Diego and back, 8/18-8/30/04, 12,452 miles on the odo
    • 51 mpg, 294 miles on one tank, SF to Santa Rosa to Chabot Science Center back to SF, 8/15-8/16/06, 33,376 miles on the odo
    All of these bests are routine for us with regards to vacation driving, but I think they can easily be duplicated for commute driving especially the 67 mpg run on Highway 80, my knee aches just thinking about that horrible commute back to SF.
    I think the real issue is the Californians that live in rolling hills in the bay area with commutes under 5 miles. The LA folks seem to always talk abot 50mpg+, eh? I think my numbers prove I can hang with the high-milers, it's just I can't make the mileage thing work on my everyday real life trips to Safeway, LOL.
  17. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(efusco @ Nov 19 2006, 12:51 PM) [snapback]351776[/snapback]</div>
    My lifetime average is 45.7 mpg after over 12K miles. If I go by a lifetime average of the MFD readings, it's 46.5 mpg. My drive is briefly described at http://www.priusonline.com/viewtopic.php?p...ighlight=#83916. I don't think given the OP's patterns he'd get even that. I'm guessing maybe mid to high 30s for a Prius and at least a few mpg less for the HCH.
    I definitely would NOT give them both the same predicted mileage.
    Here are the top 11 vehicles in terms of mileage in Consumer Reports' tests:
    http://www.consumerreports.org/cro/cars/bu...s-206/index.htm
    You can see the Prius, HCH and Civic w/manual listed. When CR tested the currenet gen Civic w/an automatic, they got 28 overall, 18 city, 43 highway.
    You can read about CR's test procedusre at http://www.consumerreports.org/cro/cars/ne...tests/index.htm but you need to have a subscription to their online service to see it.
  18. Orf
    Orf New Member
    414
    Devonport, Tasmania
    Problem 1.
    I find that at speeds less than about 60 kph I can keep the car in the glide condition (no arrows on the energy display) for pulse and glide but above this speed it becomes very difficult if not impossible to achieve this glide condition.
    I would like to see a modification that if travelling above the EV cut out speed and the EV button is selected the car goes into glide mode whenever no ICE or electric power is required to drive the vehicle. This state would equate to a pulse and automatic glide. Once the car's speed drops below the EV cut out speed the normal electric braking would be reinstated.
    I believe better fuel consumption can be had because the kinetic energy available is used directly to propel the car rather than being temporary store in the battery and then reclaim later as electrical drive. If the state of the battery was such that recharging was necessary, then the system currently in vogue would prevail until a satisfactory charge had been achieved at which time the automatic glide would be reinstated.
    Problem 2.
    Another limitation I see is in cruise control. When going down hill the current cruise control system allows the car's speed to exceed the set speed. This is no problem unless that increased speed is above the speed limit set by the authorities.
    I would like to see the Prius modified so that a second selection on the cruise control lever would limit the speed to that set and any additional speed is prevented by increased electric braking to charge the battery.
    Although this mode of drive may decrease fuel economy it would allow cruise control to be used without the fear of getting a ticket for speeding because it would hold the selected speed.
  19. Tideland Prius
    16,623
    <div class='quotetop'>QUOTE(Orf @ Nov 26 2006, 03:25 AM) [snapback]354152[/snapback]</div>
    1. Sounds about right. under 64km/h if you want to be exact ;) Higher than that, you go into hyper-stealth (lightly pressing but there'll be yellow arrows from the battery)
    2. Depends on the hill and when you set the CC. On some occasions, I've seen it hold the speed, on other occasions I've seen it let the speed increase (sometimes even on the same hill on different occasions!)
  20. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 26 2006, 12:57 PM) [snapback]354201[/snapback]</div>
    Your second point raises another question. Why do journeys over the same roads have differing fuel consumption figures?
    I recently met my first driver of a Prius while checking into a motel. Subsequent discussion revealed that he often drives a route and logs greatly differing fuel economy figures. He even stated that he used cruise control set to the same speed. The only differing elements would be traffic (not relevant said he), wind and temperature. However, the different results were such that wind and temp could not have had such an effect.
    On my 2500 km journey where I met this driver I found that travelling on a freeway that had sections of single and dual lanes my fuel economy figures varied in an unexpected way. On the single lane parts the fuel consumption 5-minute bars had about 2/3 above the 5 L/100km line. On the dual lane sections 2/3 were below the 5 L/100km line. Here is where the story gets hard to understand. On the single lane sections I set the cruise control at 100 kph (the speed limit) on the dual sections I increased the cruise control to 105 kph (the speed limit was 110 kph). Seeing my trip was over 2000 km of freeway and the same winds and temperatures seemed to prevail over the entire time I noted the fuel consumption differences I was surprised that the higher speed gave me better fuel consumption readings.
    I then ventured onto a major country road where the speed limit was mostly 100 kph. I intentionally reduced speed to 80 kph, which allowed me to use cruise control without having to slow down for bends etc., and found my fuel consumption figures were about the same as those of travelling 100 kph.
    Why does the Prius behave in this manner? It seemed to be most inconsistant and not logical.
