10th Gen Accord Hybrid Engine/Trans
Discussion in 'Honda/Acura Hybrids and EVs' started by Bigleftyinaz, Aug 10, 2022.
  1. Bigleftyinaz
    Bigleftyinaz Junior Member
    76
    San Antonio, TX
    I'm trying to figure out if there is a different combination of Engine or cvt gearing between the base/EX-L to the sport/touring model .
    Basically trying to find why the touring and sport get worst mpg besides the weight of the 19's and the circumference.
    Anything else to prevent putting 17's on a touring to achieve the mileage of the base/EX-L trim?
  2. Trollbait
    12,419
    Without diving too deeply into Accord specs, the difference in wheels is enough. Larger wheels add weight at the worse possible spot on a car. This is why the Camry hybrid SE/XSE/XLE has a lower rating than the LE.
    There could also be some extra weight from added features. So swapping on the smaller trim wheels may not get all of the improvement, but it will get most. You can also look for wheels that are lighter than the factory ones. And don't forget to check the tire weights; that varies between models of the same size.
  3. Bigleftyinaz
    76
    San Antonio, TX
    Thank you,
    By swapping down the speedometer and odometer will read different . I believe swapping down would increase the miles over the same trip ,no?
    Will Honda recalibrate if I ask?
  4. Trollbait
    12,419
    The wheels are smaller, but the factory tire size has a taller side wall than the ones on the larger wheel. In the end, the diameter and circumference of each wheel and tire combo is essentially the same.
  5. alam99
    alam99 Member
    97
    33
    Chicagoland
  6. Bigleftyinaz
    76
    San Antonio, TX
  7. Mendel Leisk
    40,923
    About half the participants in that discussion are under the (misguided) impression that going from 19" to 17" rims will reduce tire OD by 2", or drop the car an inch::
    So I will bring my car to dealer to have them recalibrate the speedometer to match the new size
    How much of a difference in ground clearance would moving from 17s to 19s make?
  8. alam99
    alam99 Member
    97
    33
    Chicagoland
    Post
    Post 44 from the Accord thread reads:
    You should be find downsizing from 19" wheels to 17" wheels as long as you maintain the same overall wheel diameter. That means that you shouldn't go with the 17" OEM tire size that Honda uses on other Accord models.
    The OEM tire size for the Accord's 17" wheel and tire package is 225/50R17- which will have a diameter of 657mm
    The OEM tire size for the Accord's 19" wheel and tire package is 235/40R19- which will have a diameter of 671mm
    That's not a huge difference- and it's certainly safe to go with the 225/50/R17 size if that's what you get... just beware that the 17" wheels will be 2% smaller- so your odometer and speedometer might be a little off.
    As always, YMMV.
  9. alam99
    alam99 Member
    97
    33
    Chicagoland
    The response seems to be that 17s will get better fuel economy than 19s as well as a more comfortable ride. The type of tire matters as well, of course, whether it is low friction or not. The stock 17 wheels are designed for better air flow than non-hybrid specific wheels so that probably helps as well.
  10. Bigleftyinaz
    76
    San Antonio, TX
    It's only 1/2" difference
  11. Mendel Leisk
    40,923
    Ideally you should stick with the stock OD, juggling tire width and sidewalk height to achieve that, or as close as practical. Unless you intentionally want to change it that is.
  12. Trollbait
    12,419
    2% is within legal margin of error of 2.5% for a speedometer. With going to 17" means your speedometer will be reading high, I wouldn't worry about it.
  13. Bigleftyinaz
    76
    San Antonio, TX
    One last question before I do this
    Which would be best
    215/55/17 or 235/50/17
  14. Mendel Leisk
    40,923
    Criteria:
    close to stock OD
    your preference
