  1. Priipriii
    Priipriii Member
    231
    67
    Went from this, to this.
    Coots, Slammed, hill and 8 others like this.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    I added USB Ports to driver and passenger side areas. Had to remove the armrest, placed a power port inside the armrest, plugged it in for power in the Cigarette lighter port and used its two 3.0 USB ports to plug in my extensions. Had to cut into the sides so the attachments could pop in.
  3. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    Do you mind sharing a picture of your wood dashboard kit? I notice you had one by the USB port? Thanks
  4. orenji
    orenji Senior Member
    5,887
    3,488
    Front end PPF
  5. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    This ninja just PPF an unpainted body kit?
    #19085 Nopho4u, Sep 1, 2022
    Matth Torrijos likes this.
  6. Matth Torrijos
    Matth Torrijos Active Member
    114
    208
    Poway
    ockevin, jzchen, Johnsk93 and 6 others like this.
  7. orenji
    5,887
    3,488
    Actually the "Blizzard White Pearl" Body Kit already had PPF, but now I have additional protection from UV on my carbon and JDM headlights (y)
    Burna J likes this.
  8. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    PPF
    IG: twnzy_
  9. Mendel Leisk
    41,884
    Took off the rear door clear plastic film bits. Warmed up with heat gun, picked at a corner and slowly pulled off. Glue residue took some elbow grease: WD40 on a rag, and some dabs of car polish got it done, but took a while.
    Some of the edges we’re getting a bit groddy so I figured it was time. I guess their intent is protection but not sure how necessary, and it seems like a grunge magnet, might promote rust.
    F8AF3760-F6E9-4700-9DD2-9AD915545089.jpeg FECE306B-5D60-42AD-A9F6-0CCA602CD5D9.jpeg
    ockevin, jzchen, Johnsk93 and 4 others like this.
  10. Montgomery
    2,254
    2,242
    Orange County, CA
    Here you go.
    icyrius likes this.
  11. Matth Torrijos
    114
    208
    Poway
    Installed cusco lower mid brace and did oil change with HKS oil
    djschwin00, Burna J and Xterra72 like this.
  12. Bill Norton
    Bill Norton Senior Member
    2,217
    745
    MONW, Ks.
    2019 Prius
    L Eco
    You added weight to you Prius with this Gee Gaw. A thing that will have no measurable difference in performance, except for the theoretical less MPG due to the weight.
    And from the scraping of the bottom that you have been doing, this Gee Gaw going to get damaged next time you scrape bottom.
    But man, when it's jacked up in the air and you can see that thing,,, beauty!:cool:
  13. Matth Torrijos
    114
    208
    Poway
    its surprisingly handles a lot better i can definitely feel the car being more stable especially on turns, i would say its worth getting if you want less sway when your turning.
    w84me, Burna J and Xterra72 like this.
  14. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    When you make a claim and bill norton sits with his arms crossed, he actually wants hard evidence so you’ll have to measure the lean of the car chassis as you turn using degree angles and change of center of gravity. If not, he ll be your biggest critic.
  15. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    Hard evidence is to install on your own car. We are posting based on pure experience. We are not trying to dispute or prove anyone wrong that it works or it doesn’t work. To each his own. I’m a believer! I’ve had mine on for a decade! It’s amazing!
    ockevin, djschwin00, Burna J and 3 others like this.
  16. Xterra72
    1,437
    1,681
    Same comment. Enjoy
    Yes ! Gee Gaw Looks nice ! Feels amazing! Way better than stock! Worth the weight and a few less mpg. So what when it handles better than stock.
    Grit likes this.
  17. Matth Torrijos
    114
    208
    Poway
    I don’t have the time to do my own video proof but bill is more than happy to sit in my car and compare it to his stock Prius then he’ll understand and feel the difference
  18. Bill Norton
    2,217
    745
    MONW, Ks.
    2019 Prius
    L Eco
    I'm glad Grit is onboard with science based proof.
    Look gang, I know cars and suspension mods.
    Bigger Badder Anti-Sway bars, stiffer, slightly lower springs, stiffer struts will all have measurable performance increases.
    They will make the car feel more go-kart like by reducing suspension 'suppleness'.
    But the real increase will be sticky summer tires. I'll put those on my stock Level 5 17" wheels and let's meet at an Auto Cross track. (JK) Those numbers are not opinions.
    But who really believes that the Prius structure is so floppity and bendable that a few Pretty Gee Gaws bolted to the very center of the car's 'tunnel' will have any measurable effect?
    I'll tell you who: The Vendors that sells the Pretty Gee Gaws.(y)
    Some even bolt on way in the back, 3 ft from the rear suspension, where the trailer hitch would bolt on, only this 'thing' is pretty. (I'm going with an ugly steel trailer hitch,,, and I'm sure my skid pad G's will be better because of the 'stiffness' it provides...:whistle:)
    Kids, clear coat or give those Gee Gaws a wax job to keep them looking pretty. :cool:
    Please, we've been through this years ago.
    I don't care, except when you convince others that there is something to these dealios.:unsure:
    Please ignore this post....:(
  19. hill
    8,913
    That red car sure looks sweet!
    I always knew you were a closet Tesla lover .....
  20. a4rings
    a4rings Junior Member
    SF
