Fuel Cell Car Depreciation
Discussion in 'Fuel Cell Vehicles' started by bwilson4web, Dec 16, 2020.
  1. bwilson4web
    16,130
    I monitor but not closely follow fuel cell technology. There are basic thermodynamic and chemical problems with the hydrogen versions that make them impractical. Some of the high temperature, carbonate cells have interesting capabilities and some of the methane fed ones where waste heat is reused also make some sense. Regardless, I was not aware of this August 2019 video:
    While the Toyota Mirai remains a really hard car to get hold of in most of the world, there are some places in the U.S. where you can get one rather easily -- thanks to ex-lease cars now entering the used car market.
    What's more, they're being sold at a fraction of their as-new price... but why?
    Nearly a year and a half old, how bad is it today?
    ammdb likes this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Yep.
    Seen them wholesale prices near $5,000.
    And even a few at $1,000 and $3,000.
    Crazy price for such a beautiful car.
    But without fuel infrastructure I suppose to he car isn't much good.
    #2 ericbecky, Dec 17, 2020
  3. Trollbait
    12,447
    There is also the end of use date for the tanks, and the durability of the fuel cell. By 75,000 miles, the cells have lost 10% of their power, on average. Those may not be a big impact on out of lease cars, but will be driving depreciation faster than other cars.
    The Clarity FCEV was lease only, and Honda is just crushing them after.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    No such lose in power reported. Sounds like back in the day when Prius Batteries were reported to cost $5k to $6k to replace. All false rumors. Fuel Cell tanks are good for 15 years. Just like a Hybrid battery. Can be replaced when the time comes.
  5. bwilson4web
    16,130
    I don't have fuel cell, hands on, experience. However, my understanding is ordinary air also has trace gasses that poison the fuel cell chemistry over time: The Case of the Poisoned Fuel Cell | Science | AAAS
    . . . Hydrogen fuel cells have their own Achilles' heel, however: They are easily poisoned by carbon monoxide (CO). Now, researchers report that they've created novel catalysts for fuel cell cars that strongly resist carbon monoxide contamination, potentially solving a problem that has vexed the industry for years.
    If even minute quantities or carbon monoxide are present in that gas, it can poison the platinum catalysts . . .
    In contrast, the batteries 15 years from now will have different chemistries, lighter, more energy, and a structural part of the car body. In contrast, fuel cell tanks are not part of the body today although I can see a future version with long cylinders that might be structural.
  6. Trollbait
    12,447
    Actual measurements of fuel cell output from fleet cars does show a power loss. The average power loss was 10% after 75,000 miles. Some cars had less, some had more. From almost none to over 30%.
    The cost of the tanks means the majority of the cars will be scrapped when the tanks reach their end of life date. Used ones from totaled cars will be an option for some, but there won't be any refurbished ones, as with batteries.
    bwilson4web likes this.
  7. orenji
    5,887
    3,488
    Who knows what will be available in 15 years or what will be the process for new tanks.
  8. Trollbait
    12,447
    It is a legal and liability issue with the tanks. The material oxidizes and ages over time, even the steel tanks. So they might get weaker. No one wants to do the effort of recertifying old tanks, because they don't want the be liable in case something goes wrong with one. A tank rupturing while filling is a bigger deal than a battery not holding a charge.
  9. bwilson4web
    16,130
    The physics and chemistry says even 15 year from now, BEV will remain 3x more efficient than hydrogen fuel cells. I'm patient as no 'law' or 'regulation' can change physics and chemistry.
  10. hill
    8,732
    if expiration graph is carried out - the car will have been scrapped 5 years ago. That's some serious disposable philosophy. But good for the manufacturers bottom line.
  11. orenji
    5,887
    3,488
    Tanks are Carbon Fiber and will last much longer than the 15 years. It’s all the fuel lines that would need to be replaced.
  12. hill
    8,732
    Even relatively low pressure LPG tanks have to be recertified at every 10-12 years.
    Now you're talking thousands LBS per sq".
    Even low pressure LPG fill stations won't refill past expiration.
  13. Trollbait
    12,447
    CNG carbon fiber tanks are good for 25 years since date of manufacture. They are only containing around a third of the pressure a hydrogen tank sees, so experience less stress during use. Methane is also less likely to have a negative interaction with the material.
    The fuel lines see something around 200psi, but may need regular replacement from hydrogen embrittlement.
    hill likes this.
  14. orenji
    5,887
    3,488
    Speaking with one from Toyota Corporate the fuel tanks will be much more affordable in the years ahead, just as Hybrid batteries have come down in price.
    The used car market has seen the prices of used certified Mirai reach prices that are double what they were two years ago.
  15. Tideland Prius
    16,508
    So the warning label is for the fuel lines and not the tanks? I assume that’s cheaper than replacing the tanks or a hybrid battery at 15 years?
  16. orenji
    5,887
    3,488
    Warning label states the tanks, but I am sure the lines would be covered during the replacement of the tanks.
    Tideland Prius likes this.
  17. Trollbait
    12,447
    The warning is a regulatory safety requirement by the USDoT. It is required with all such high pressure gas fuel tanks that they only have a finite service life in terms of years. For CNG tanks it is longer than hydrogen because of the pressure and chemical differences. I'm guessing fuel lines are good as long as they pass inspection.
    CNG tanks of roughly the size the Mirai uses are in the $1000 to $2000 range. Hydrogen tanks will be more. Don't forget there is also a hybrid sized battery, and fuel cell itself that might need replacing.
    hill likes this.
  18. Tideland Prius
    16,508
    So except for a small portion of the population, it’s essentially disposable?
  19. Trollbait
    12,447
    Pretty much.
  20. Tideland Prius
    16,508
    Sigh
