Hybrid battery low in the mornings; 2 bars usually. Sign of impending failure?
Discussion in 'Gen 2 Prius Main Forum' started by SRQ, Sep 7, 2022.
  1. SRQ
    SRQ Member
    158
    56
    I've noticed that in the mornings the Prius will struggle to find the power to climb up the hill, and then see that the battery is low, around two bars.
    Then once I drive it a little, it goes back to normal. Is it time to start looking for a new one/doing a DIY repair on a bad cell or two? 12v was replaced a little more than a year ago.
  2. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    it’s time to not worry abt it and wait til codes pop up. there is no predicting when your battery will fail. if you’ve got the time and money to replace the battery prematurely, then you could go that route too
    srellim234 and douglasjre like this.
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    If you're not already doing so, it would be best to let the vehicle warm up before climbing.
    Have you had a chance to balance or recondition the HV battery?
  4. Tombukt2
    13,291
    2,398
    Batteries need to discharge and recharge it's like a life cycle thing it's how batteries live so if you spend a lot of time looking at your display in worrystion. Then that may be how you live. I don't know personally some people are just like that they spend a lot of time studying and then they study long and they may study wrong and it may cost them I would say enjoy and drive the pee pee out of your car and when you have some codes and things start happening then we start to address them worrying about your battery gauge going up and down is kind of a sort of senseless worry if you had other things that were less important that you monitored the battery on you would see similar things but those things aren't as important like headphones and you know whatever just other battery things. Good luck man
  5. bisco
    52,286
    2 bars in the morning are normal if you park the previous night with 3-4 bars
  6. SRQ
    SRQ Member
    158
    56
    All points noted. I have a second vehicle so when it eventually happens I won't have much of a life interruption.
  7. netsplit
    netsplit Junior Member
    48
    Earth
    Mine followed that pattern and I'm currently servicing the battery because it failed. If you'd like a data point. I got about a year and a few months then it failed after it started that pattern. My mileage also dropped 4-8 mpg in the last 6 months.
  8. Tboy160
    Tboy160 Junior Member
    27
    Flint, MI
    I have 2 Gen2's. Both over 300k. One of them keeps strangely having a super low Traction/HV battery in the mornings. It's my wife's car, I've noticed it the last couple weekends.
    I mean I go to take off, I'm like man why is this so weak, then I see the battery indicator down to 1-2 bars. When it happened once or twice, I didn't think much, but it's happened several times now.
    I would assume something is draining it. My guess would be one of the 28 cartridge deals? But I don't know much about them?
  9. Tboy160
    27
    Flint, MI
    Advance auto claims the 12volt battery tests as a good battery. Not sure if their tester is even designed for these batteries
  10. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    Get an OBD2 dongle and a copy of Dr. Prius, measure the battery voltages the night before, and the next morning, and report back.
    (Note, only get one of the OBD2 pieces that is recommended, or it might not work.)
    Since you are in Michigan, is the car suddenly seeing extreme cold temperatures?
  11. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    You can restore the capacity on these batteries with a grid charger and discharger, and these symptoms will go away, but since the batteries have over 300k miles on them, this will most likely have to be done every 12 months.
  12. Tboy160
    27
    Flint, MI
    So, it never did this again.
    Well, once about a week ago, but I have no idea what factors could be so wildly intermittent??
  13. Tombukt2
    13,291
    2,398
    They need to be driven if they're not being driven things go down and become less very quickly batteries etc so when you go from having one of these and driving it 24/7 and all of a sudden you have kids and other parts of life creep up and the car sits before that happens you should put somebody in it that's going to use it like you did and you get yourself a Yaris or a Corolla or a Jaguar for all I care but I'm just saying the hybrid won't be the thing then for your situation more than likely or you'll pay the premium to keep it at the ready for when you want because the hybrid's not going to like sitting.
  14. pasadena_commut
    2,776
    831
    Southern California
    Not unless you have money to burn and another car to use when that one is in the shop. The "big" expenses for fixing a 2nd generation prius (the pack, the ABS) are chump change when it comes to maintaining a Jag.
    Brian1954 likes this.
  15. netsplit
    48
    Earth
    Last month I got a battery code, but it wasn't the cells, the battery computer had some corrosion on one of the terminals. I removed it, and cleaned the pins and the code hasn't came back. So on a year and a half since I did the maintenance on it.
    The other Prius the cells aren't as good and did throw codes. Ended up getting a refurbished battery and it's been solid.
  16. Tboy160
    27
    Flint, MI
    It's doing it again. It sat for 2.5 hours, as I started driving it was at 4 bars but those plummeted quickly, down to 1 bar, then climbed back to normal. I've seen this several times now. Seems crazy!
