Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. 200Volts
    200Volts Member
    439
    46
    Northern CA
    My most obscure Prius fact: The FM radio cannot be switched between FM1 and FM2 while in reverse.
    (edit: By pushing the FM button).
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    How about this?
    EPA City MPG is higher than Highway MPG.
  3. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    <div class='quotetop'>QUOTE(200Volts @ Nov 20 2006, 03:31 PM) [snapback]352287[/snapback]</div>
    That's because the Doppler effect on radio waves in reverse would cause FM2 to be lower than FM1, which would violate FCC doctrines. It's a little know fact that this was the cause of Janet Jackson's wardrobe malfunction at the Superb owl. :blink:
  4. qbee42
    3,082
    <div class='quotetop'>QUOTE(narf @ Nov 20 2006, 07:02 PM) [snapback]352303[/snapback]</div>
    The lesser known "Part 14" of the rules and regulations.
  5. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    The fact that the car carries a spare tire seems to evade a certain
    percentage of the owner population...
    _H*
  6. Tom_06
    Tom_06 Active Member
    609
    143
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(200Volts @ Nov 20 2006, 05:31 PM) [snapback]352287[/snapback]</div>
    The HID headlight auto-leveling system adjusts only for vehicle pitch caused by things like carrying a heavy load. Many people incorrectly think it adjusts for going up and down hills. The really obscure part: it doesn't operate between 0.4 mph and 19 mph, or above 112 mph. Even more oddly, it doesn't control at all while accelerating.
    Here is the page from the service manual that details this:
    [attachmentid=5730]
    - Tom
  7. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    The Prius Steering wheel is not circular, but oval. This permits better veiwing the the speedometer and other controls during straigt driving.
    Once you get used to it, it also results in easier reach for hand/over/hand steering.
    Data Daedalus likes this.
  8. derkraut
    derkraut Member
    299
    28
    SAN
    I don't know whether this qualifies as "obscure"; but driving the Prius is highly addictive. :rolleyes:
  9. Warwind
    Warwind New Member
    137
    Hedgesville, WV
    The passenger's vanity light can't be switched on unless the mirror cover is first slid open. The driver's vanity light can't be switched on unless the mirror cover is slid open, AND the car is not moving.
  10. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    There's a sooper-seekrit storage container under the front cupholder.
  11. McShemp
    McShemp New Member
    371
    SA, TX
    In the image of the Prius on the Energy screen, The two wheels on the left side of the Prius (bottom of the screen) have five spokes. The other wheels (top of the screen) only have four.
  12. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The stereo can be turned on from the steering wheel by pushing twice on the 'mode' button.
    edit: I was wrong. Once is enough.
  13. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    While listening to a CD, hold the up or down arrow for a few seconds; it will change to the next / previous CD.
  14. ceric
    ceric New Member
    1,114
    Fremont, CA
    The front-left side is lower than the front-right side. If you don't believe me, measure the height from ground to the lower edge of side mirrors. They diff by about 1 inch. <_<
  15. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    <div class='quotetop'>QUOTE(Warwind @ Nov 20 2006, 06:52 PM) [snapback]352357[/snapback]</div>
    I'm not sure this is true. I'm sure I've done this while moving, though it was in slow traffic. (I'm a diagnosed fidgiter. Anything with a hinge wears out faster when I own it.)
  16. GeekEV
    GeekEV Member
    417
    NorCal, USA
    This is not true on my '06. I could turn on the driver's vanity light while the car was in motion just fine.
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(ceric @ Nov 20 2006, 08:32 PM) [snapback]352394[/snapback]</div>
    measure the height of the doors instead. the right side mirror is positioned higher in order to be seen from the opposite side of the car.
    also on the vanity mirror, the light on the drivers side does work when its moving. have used it many times. the switch must be on to work though.
    all in all, this is an interesting thread. gotta go out and check on a few of these
  18. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    The steering wheel, like the Earth, is not round.
  19. KTPhil
    KTPhil Active Member
    1,379
    22
    "Even more oddly, it doesn't control at all while accelerating."
    Actually, it HAS to work this way or the car would be "chasing" the adjustment every time you sped up or slowed down. The rear suspension conpression is the same whether from load or acceleration. By disabling adjustment while accelerating, the system ONLY adjusts for load.
  20. Tom_06
    609
    143
    <div class='quotetop'>QUOTE(KTPhil @ Nov 20 2006, 10:55 PM) [snapback]352405[/snapback]</div>
    I understand the implication, I just found it odd that it wouldn't adjust for acceleration. As you say, the compression is the same as from load. I would think you would want to adjust for that tilt whether from load or acceleration. I am pretty sure my old Audi A6 with HIDs adjusted for acceleration, but since it was a turbo, acceleration squat was way more dramatic.
    Maybe the update rate is too slow for acceleration changes. Makes it so the system doesn't hunt (or "chase") and only corrects for slow and steady changes to the car body stance.
    - Tom
