Do rear brakes activate always, despite regenerative braking?
Discussion in 'Gen 4 Prius Technical Discussion' started by Hanzou, Sep 12, 2022.
  1. Hanzou
    Hanzou New Member
    Australia
    ----Australia----
    I have read that, when braking just a little bit in the Prius, only regenerative braking activates. But because regenerative braking works with the front wheels only, does that mean that the rear wheels don't receive any braking force at all in these cases? Or do the rear friction brakes activate in conjunction with regenerative braking in the front, to give a better overall stability to the car even during this slight braking events?
    Then when more braking is needed, is this the sequence? Regenerative front only --> regenerative front + friction rear --> regenerative front + friction front + friction rear.
    Thank you!
    Hanzou
  2. Tideland Prius
    16,634
    Not quite but you're close.
    Regenerative braking is done by the electric motor (MG2). This motor is mounted in the front which may explain the confusion about "front braking". When coasting (no pedals depressed) or lightly braking, the braking force is done by the electric motor (now called a generator because it's working in reverse).
    When you require greater braking power, the brake pads (both front and rear) will blend in to assist the electric motor. We don't know what the % split between front and rear friction braking is as the computer will determine that.
    So it's basically: Regenerative braking --> Regen + friction brakes (of unknown split between front and rear brake pads).
    However, given that the front discs are larger than the rear, one can surmise that the braking power from friction braking will more likely come from the front brakes.
    Hanzou likes this.
  3. ChapmanF
    18,801
    Regen is much as if you were in a conventional front-wheel-drive car and downshifted in order to slow the car. It acts through the drivetrain, and therefore only on the front wheels. The friction brakes, whether front or rear, are uninvolved, until more slowing is needed.
    Hanzou likes this.
  4. bisco
    52,596
    someone here @Mendel Leisk ? said a scanner should pad movement from the beginning of pressure on the pedal
  5. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    When I got my brake discs replaced recently, my brakes were insanely squeaky for a while. This allowed me to experimented with it to figure out the answer to exactly this question.
    Basically the rear friction brakes are on, to some extent, whenever you press the brake pedal, even slightly. At this level it's to keep the car balanced, just like in a traditional car, by splitting the braking between the front (regen) and rear (friction) brakes. The harder you press the brake pedal, the more regen and rear friction braking occurs, until......
    The front friction brakes come on once you're applying enough brake pressure to exceed the maximum regen (you can see this on the hybrid system information screen's graph, when the light blue curved bar hits the lowest it can go while braking).
    As to how much is regen and how much is friction braking depends on many things (e.g. battery level, battery temperature, driving mode, D or B, etc). At this harder braking level the braking is split between regen on the front, and friction on both the front and rear.
    Below around 4 to 5mph it's always purely friction braking.
    The simulated engine braking (not pressing any pedals), is entirely achieved with a small amount of regen.
    If the battery gets full or hot, or you switch into B (engine Braking) mode on the gear selector, then the ICE will rev up when you take your foot off the accelerator, and more so as you press the brake. This is genuine combustion engine braking (converting kinetic energy from the wheels into heat in the engine) and replaces what braking the regen be would have normally been doing in these circumstances, and more so in B mode. If the battery isn't full while in B mode, some regen still happens, just not as much as when in D.
    #5 The Professor, Sep 12, 2022
    dacoobob, amos, Hanzou and 3 others like this.
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Friction brakes are also in use 100% if you are coasting in NEUTRAL, which is not generally recommended.
  7. Mendel Leisk
    42,098
    All I know: anytime the car's been washed (or driven in rain), then sits a few days, with the rust build-up on the rotors, you hear the brakes with every push of the pedal, and it seems like all four corners. For the first block or so.
    Hanzou and mjoo like this.
  8. RGeB
    RGeB Member
    119
    Australia
    It may be similar (if a bit more complicated) in an AWD HV. In my gen5 rav4, the Toyota rear motor brake regen PID always shows zero, but I think this is wrong as the car shows rear motor regen on the dash MID. Also Toyota only supplies one wheel cylinder (friction brake) sensor PID, so I can not distinguish the front-back effect. But you can still see (MG2 = front) regen torque versus friction braking (Wheel Cyl. sensor voltage) in the attached log. 1.jpg
    Mambo Dave likes this.
  9. fuzzy1
    10,630
    I'm seeming to remember past discussions and braking-force-vs-time graphs indicting that initial foot pedal braking is mostly friction, because it is quicker and more certain. But then the ECUs quickly switch it over to almost all regenerative braking, as available (battery temperature limits and other factors permitting), though a small amount of friction braking always remains. Is this true of Prii too, or just some other designs?
    Included graphs were something like this one (not Prius-specific):
    I'm not remembering the front vs rear distribution of the friction element in this mode, though the regen element is certainly just at the front.
    Of course, this friction portion doesn't apply to pure D- and B-mode engine braking without the foot pedal.
    Separately, I'd also note that the Prius maximum regeneration is often less than many people think. It is easy for traditional ICE drivers to initiate braking too late for efficient regen energy recovery, necessitating more brake force than regen can provide, thus adding wasteful friction to reach the full requested braking level. Or use pulse braking with pulses far above the regen limits, then wasting regen potential during the pauses between pulses, as my spouse was trained a half century ago and simply will not change old habits.
    #9 fuzzy1, Sep 12, 2022
  10. RGeB
    RGeB Member
    119
    Australia
    I take such 'idealised' graphs with a grain of salt. Here is a closer view of the real log above. When the vehicle speed is decreasing quickly, we can be sure that the brake pedal is active, and often there is a lot of regen. before any wheel cyl. sensor voltage. Also (not shown here but in other logs), it does not take long downhill to "fill" the traction battery; then there is engine braking (seen as negative torque by ICE {with +ve rpm}, often with +ve torque by MG1), and I expect more friction braking if the brake pedal is pushed.
    dacoobob likes this.
  11. Tideland Prius
    16,634
    This one is from the Tokyo Motor Show Press Release
    fuzzy1 likes this.
  12. RGeB
    RGeB Member
    119
    Australia
    Still looks like a highly idealised 'example' to me. Must surely differ depending on how hard the brakes are pushed.
    Often regen. alone in my (rav4 hybrid) logs.
    Is there nobody on PriusChat with:
    (a) a Prius, (b) an OBD reader capable of logging readouts from Toyota PIDs, and (c) interest to explore such matters?
  13. RGeB
    RGeB Member
    119
    Australia
    As an example, here is a log that shows (a) friction braking at low speed, (b) regen. without friction braking at higher speed (c) engine braking when traction battery SOC rises and car goes downhill, (d) some heretical things ...
  14. ChapmanF
    18,801
    One possible complication is that the time period on which the OBD reader re-fetches the PIDs may be slow enough to miss interesting things.
    Old-time member hobbit once put some LEDs on the dash wired directly to the fluid pressure sensors, to display the pressure changes in actual real time.
    Of course, that was in a Gen 2, where the wiring from the actuator with the sensors to the ECU was accessible.
    RGeB likes this.
  15. RGeB
    RGeB Member
    119
    Australia
    Modern OBD readers are fast (100 PIDs per second with OBDLink MX+). That should show everything implied in the idealised examples. But, in support of the input from ChapmanF, Toyota uses various refresh times for the Toyota car PIDs. I suspect that these must be very short for things that control braking.
    I only logged once per second (the reader can go much faster, and you can choose only to log when a PID reading changes, but files may get big unless the number of logged PIDs is limited). You can see the 1 second effects in some of the stepped lines above.
    Humans have trouble looking at multiple momentary gauges per second, but logs can reveal much more.
  16. RGeB
    RGeB Member
    119
    Australia
    That article by Hobbit, linked by ChapmanF, is excellent to understand better how far from the idealised examples is the real braking algorithm in a Prius. Thanks for the link ChapmanF. My guess is that all the wheel cylinder sensors in current Toyotas feed into the CAN bus to be used in VSC ASB etc. But so far I can only find one (and it is not specified which one) in the PIDs licensed by Toyota.
  17. ChapmanF
    18,801
    Gen 2 Prius had separate pressure sensors measuring the actual pressures to all four wheel cylinders (plus two master cylinder sensors and one accumulator sensor).
    Gen 3 has no wheel cylinder sensors. It does have a single "front wheel cylinder pressure sensor" for the pressure supplied in common above the FLH and FRH valves (plus one master cylinder and one accumulator sensor).
    Gen 4 has only accumulator, stroke sensor, and servo pressure sensors.
  18. RGeB
    RGeB Member
    119
    Australia
    So what would Hobbit use to sense friction braking in a gen 4?
  19. ChapmanF
    18,801
    Psrv would be the closest available proxy for what's going out to the wheel cylinders, but there's only one of it, and it's too far upstream to tell you what the ABS actuator might be doing to vary the individual wheel pressures.
  20. RGeB
    RGeB Member
    119
    Australia
    I see PIDs for ON/OFF Status of each of the ABS Solenoids shown in the Brake Actuator Assembly (SFRH etc). Could that help?
