  1. a4rings
    a4rings Junior Member
    SF
    Looks fantastic, what rear bumper/diffuser is this??
  2. a4rings
    SF
    Thats awesome man, did you notice a noticeable bump in power?
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Negative
  4. Matth Torrijos
    Matth Torrijos Active Member
    114
    208
    Poway
    Installed ceramic headers and shift power throttle controller 20220926_140159.jpg 20220924_180329.jpg
  5. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    Finally did something to the car in a while.
    Noticed the rear passages were missing something. Ordered OEM USB/USB-C plug, wiretap it to the easily accessible cigarette liter and done.
    Clay Meyer, Coots, Xterra72 and 5 others like this.
  6. Matth Torrijos
    114
    208
    Poway
    Big update/upgrade on the prius:
    Hotchkis Front Sway bar
    Hotchkis Rear Sway bar
    Cusco Front Chasis Power Brace
    Cusco Front Strut Tower Brace
    Modellisa v3 full body kit
    ockevin, Slammed, Xterra72 and 3 others like this.
  7. w84me
    w84me Active Member
    144
    224
    Sacramento
    Where did you buy the usb/c outlet?
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    You should be able to find it on Amazon. I got mine there.
    w84me likes this.
  9. Matth Torrijos
    114
    208
    Poway
    4115A1E9-0F74-4ACA-BF8D-1BCDFE23A353.jpeg Front “Modellista” V3 installed
  10. KamiKKazi
    KamiKKazi Member
    91
    58
    OC
    full set of cusco braces minus cusco sway bars, urethane exhaust hangers, 9-drive throttle controller from amazon, swap moog end links to mevotech TTX endlinks, new ultra power steering rack and mevotech outer tie rods, -3.1 front camber with 4 camber bolts, hood hinge lift spacers and air-x ebay intake (injen rep). Sitting on Tein Flex Z lowered max. This 2010 with 238K drives better than new.
  11. Matth Torrijos
    114
    208
    Poway
    F1C6999C-2D62-4133-8A02-3EE7471DEB2F.jpeg 2E1C529F-7F44-404B-ADFF-BA3F81F77759.jpeg Brought my Prius to the desert last week
    Xterra72 likes this.
  12. WesleyRiccipio
    WesleyRiccipio Junior Member
    103
    24
    is that a boat... on sand? :)
    Burna J likes this.
  13. Prius204
    Prius204 New Member
    Winnipeg
  14. hill
    8,897
    Thought it was the old shoreline of Lake Mead as it continues to dry up.
    WesleyRiccipio likes this.
  15. WesleyRiccipio
    103
    24
    we are changing
  16. w84me
    w84me Active Member
    144
    224
    Sacramento
    Look up “officialpriusgang” on Instagram. They sell product there
    Prius204 likes this.
  17. Matth Torrijos
    114
    208
    Poway
    723698B5-952A-485E-8910-BA8CBEF40C1F.jpeg Did a burnout on the prius
    KamiKKazi, Johnsk93 and Montgomery like this.
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    the Traction Control system in a 2015 allows you to do that?
  19. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    They can chirp for sure, normally ..... gen 4 anyways, I'm sure with a bit of practice ....
    #19119 vvillovv, Jan 13, 2023
  20. SnowMexicanuck
    56
    66
    Quebec, Canada
    Probably in Maintenance Mode, but it's really not recommended...
