12V dies every two years
Discussion in 'Prime Main Forum (2017-2022)' started by mveras1972, Sep 29, 2022.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I've read other threads circulating this topic but none touch on this particular issue: Is it normal for a 12V battery on the Prius Prime to die after a couple of years? I bought my 2017 Prius Prime in 2019 and replaced its 12V battery in October 2020 and I thought it was the original battery. I figured it's a 2017 car which was probably first owned in 2016-2017, so 3 or 4 years for the battery to die a bit premature, but I thought it was ok. However, it is now just about to be October 2022, nearly 2 years after I put a new battery on the car, and it needs replacement again. When I took it to my dealer today, they looked at the history and I was surprised to discover that the 12V battery in this car had been replaced twice before I bought it, one time in 2017 and another time in 2019 just before I bought it. So, we're talking about replacing this car's battery about every 2 years. Is this normal?
    FYI, I drive this car daily. It is not sitting parked for more than 24 hours ever (except during the lockdowns during the COVID pandemic or when I travel by plane which is about once a year). I charge the EV battery almost daily. So I don't understand how this 12V battery dies every couple of years. Is there something wrong with my car? I took it to the dealer today for service and I asked they diagnose the charging system on the car since I don't believe this is normal. We'll see what they find out.
    buztabuzt likes this.
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Not saying it’s your situation, but letting the 12 V deplete excessively even a few times can destroy it.
    douglasjre likes this.
  3. Gokhan
    Gokhan Senior Member
    6,549
    2,613
    Paramount CA
    Are you sitting in your car with lights on after you turn the hybrid system off or something? Do you keep the charger plugged in, which reportedly drains the 12-V battery? No, this is not normal. You are probably doing something wrong. It should last for many years under normal conditions.
  4. bisco
    52,399
    you're going to have to measure the current draw with the car off, to see if it is excessive.
    sitting during covid might be the only problem, and don't leave the car plugged in, that will drain it.
  5. Washingtonian
    Washingtonian Senior Member
    726
    621
    My 2017 has the original battery. I don't give it any special attention. If I get home at 2 or 3 PM, I plug the car in and usually unplug it the next morning. I expect it to someday fail, so I carry a small 12V jump starter in case that should happen when I am not at home.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    There was/is a problem in some Prius Primes where the Safety Connect communication device does not turn off as it should when you turn off the car. As such the Safety Connect communication device is always drawing 12v power. Solution has been software fix by dealer.
  7. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    You should be able to get at least 5 years out of a battery unless you deplete it a few times where it won't start the car.
  8. BiomedO1
    4,163
    2,180
    SacTown, Ca
    I always check the electrolyte levels in all my car batteries in the fall and usually get 8 to 10 years out of them. Two year battery replacement on a daily runner; you've got an internal drain somewhere. As Marine Ray stated; something isn't turning-off. The problem here is also complicated by the CPUs in this car that will only charge the 12VDC battery to a point, then redirect the current to recharge/regenerate the traction batteries. On a conventional car, as long as the engine is running, the battery is being charged.
    Making sure you car has all of it's software updates would be a good start.
    Hope this helps.
    buztabuzt, PT Guy and Marine Ray like this.
  9. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    my 2020 is still fine, though my mazda3 i only got 3 years out of, upgraded that to a Northstar and never saw a lick of problems again.
  10. Gokhan
    6,549
    2,613
    Paramount CA
    You should easily be able to measure the current draining from your 12-V battery using your smartphone.
    Your smartphone has a Hall-effect sensor, which measures the magnetic field B. You can install one of many apps to measure the magnetic field B. The magnetic field B is directly proportional to the current I through the battery wire and inversely proportional to the distance r from the battery wire. Note that you need to align the sensor to get the maximum magnetic field, which is in the direction perpendicular to the wire.
    The current I is given as:
    I = 2πrB μ
    μ₀ = 4 × 10⁻⁷
    This simplifies as:
    I = 5rB × 10⁶ (I in amperes, r in meters, B in teslas)
    or
    I = 5rB (I in amperes, r in centimeters, B in gausses)
    Therefore, if you use the gauss scale in your smartphone and use centimeters for measuring the distance from the wire, all you have to do is to multiply the distance r with the magnetic field B and then by 5 to get the current I in amperes. Make sure that you orient your smartphone to get the maximum magnetic field, which is perpendicular to the wire. However, you need to measure the magnetic field away from the wire with the phone oriented in the same direction as when it was close to the wire to account for and substract Earth's magnetic field, which will also be significant.
    CR94 likes this.
  11. Washingtonian
    726
    621
    A more easy way is to use a multimeter with an amp scale. I have a Fluke 77 multimeter. First move the common (black) lead on the multimeter to the 10A input. Under the hood, remove the negative (black) battery lead. Ensure that everything is off on the car, the doors are closed, and the key is not in the ignition. Touch one lead of the multimeter to the disconnected negative battery lead and the other to the negative battery terminal. You have now placed your multimeter in series with any power drain on the car. Read the output. With no drain it should read about 50 milliamps. Much more than that, you have a parasitic drain. To find it, start pulling and replacing the fuses, one by one until the meter reading drops. Start with the fuses under the hood. If there are fuses under the dash, you will need to disconnect the meter, open the door, then put a clamp on the door light switch to ensure it stays off while you are in the car. Then reconnect the meter. Eventually you will find the circuit that is causing the current draw.
    I understand what Gokhan is saying as I am a former Master Chief Electronics Technician from my Navy days. But you need to measure the amount of current draw, not just note that there is one.
    buztabuzt, E-GINO, Scott 13 and 2 others like this.
  12. Gokhan
    6,549
    2,613
    Paramount CA
    That's not really the easier way. That's because you need to disconnect the 12-V battery, which will reset everything and then you will have to reprogram it. Not to mention the need for tool use. I wouldn't suggest the Hall-effect sensor otherwise. A multimeter would be useful if you want to determine the exact current during a certain situation. So, perhaps you can do the diagnosis you mentioned with a multimeter but at the cost of disconnecting the 12-V battery.
    There is probably a third way though, which would be the best way if you could figure it out. The 12-V battery has a battery sensor installed on the negative (−) terminal. If you can access the battery-sensor information using an OBD-II reader, it will display the current, voltage, battery temperature, SOC (battery charging percentage), SOH (battery degradation percentage), SOF (starting performance), and self-diagnosis result for the 12-V battery.
    Doug McC likes this.
  13. rjparker
    10,536
    6,616
    Excessive parasitic draw is sure to be the issue. Normally these cars will be 10-30 ma after a short shutdown period of 5-15 minutes. Finding the sorce of the excessive parasitic draw is typically the hard part.
    Using a dc clamp meter to read 50 ma or lower is not reliable in the least. That applies x10 to some attempt to use a smart phone's sensor. A direct series connection is the preferred method and can be done without losing settings. One way is to put a jump box on the cables prior to disconnecting them to insert the meter. The more common way most mechanics use simply uses a procedure that includes a jumper as illustrated below.
    mountaineer and Gokhan like this.
  14. BiomedO1
    4,163
    2,180
    SacTown, Ca
    You guys also must remember the delay power-down sequence and sleep timers. Bring your fob within range, certain things power-up and your back to square one. Open a door, the current draw will jump. Asking your phone for a status update on your car will do the same.
    You'll have the least amount of variations by placing a meter in series.
    Hope this helps...
    mveras1972 likes this.
  15. Doug McC
    Doug McC Senior Member
    1,083
    422
    Midwest
    2022 Prius
    Minimizing parasitic draw by customizing the various settings such as setting the interior lights not to come on every time you approach the vehicle with the fob, the interior light delay to the lowest setting, coming home light delay to lowest, etc. etc. can make a huge difference in battery life and even help MPG usage. Even little things like remembering to close the windows before shutting it down (so the hybrid system powers them instead of the 12 volt battery) can make a lot of difference. We even go so far as to put the fob to sleep once we get home so it isn’t communicating with the Prius all the time.
  16. Gokhan
    6,549
    2,613
    Paramount CA
    Yes, I figured this out after I posted and I was going to post about it. Using a shunt wire before disconnecting the negative terminal to connect the ammeter in series would solve the problem of disconnecting the 12-V power from the system. However, one needs to be careful with the connections and remember to connect the shunt wire back before removing the ammeter. Moreover, you need alligator clips and some wire. As long as you are careful, have the right parts, and have some knowledge about circuits, it is a fairly simple task.
  17. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    How do you put the fob to sleep?
  18. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    While holding down the top (lock) button, double-click the unlock button below it. The light will blink four times to show that the fob has gone to sleep.
    I do it regularly when I park overnight in a house driveway, so that the car can't be stolen with a fob relay attack or whatever they call it.
    douglasjre, BiomedO1 and Doug McC like this.
  19. BiomedO1
    4,163
    2,180
    SacTown, Ca
    Yep, I also have Faraday bags placed around the house. In case the other half doesn't properly put the fob to sleep. All fobs for the other cars are placed in Faraday bags.
    I know some people just stick their fobs in the fridge, but the cold messes with the batteries.
  20. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    10/16 build date on my Prime, and the original battery is still going fine. It tests good with an electronic battery tester. I do check the electrolyte levels every year or sooner, and a couple of times a year I put a good charger on it and top off the charge to 14+ volts which may have some equalization effect.
