2022 Bolt EUV Initial impressions
Discussion in 'GM Hybrids and EVs' started by jerrymildred, Sep 10, 2022.
  1. mikefocke
    3,991
    1,801
    Sanford, NC
    Crazy how states consider solar and HOAs/POAs. I've seen everything from HOA has no vote, to HOA can argue for where it goes, to HOA can not even delay it. All depends on the state laws and courts and your covenants.
    I explored solar last month and the only place it made economic sense would have been the front and non-symmetrical and thus ugly and detract from the value of the house. Since I will sell in a few years, just couldn't make it happen. Disappointed.
    Chevrolet just announced a whole series of EVs for mid '23 delivery.
    ColoradoCrow and jerrymildred like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    Well, THAT stinks! :mad:
  3. Trollbait
    12,518
    Guess I might just be blocking mine. It does help when working with AC.
    jerrymildred likes this.
  4. jerrymildred
    11,517
    14,150
    Tampa, FL
    Efficiency is what's surprised me the most. Since it's punching a bigger hole in the air and weights a few hundred pounds more, I'd expected a bigger efficiency penalty. In fact, this thing is doing almost as well as the Prime and often better like in my drive home from work yesterday. I already mentioned the drive on Monday, but this one was also amazing to me.
    Zythryn likes this.
  5. Trollbait
    12,518
    Did you beat the EPA by such margins with the Prime?
  6. jerrymildred
    11,517
    14,150
    Tampa, FL
    Yup. Lifetime average was 5.1 m/kWh which converts to 171.8955 MPGe compared to the EPA estimate of 133 MPGe.
    EPA MPGe combined on the Bolt EUV is 115 MPGe which is 3.411957 m/kWh.
    BTW, the lifetime average on the Bolt EUV started at 3.8 when we got it. It slowly went up to 4.5. Then it was at 4.6 for a few days like in the picture above. Yesterday it went up to 4.7 m/kWh which is 158.4135 MPGe. Unless I take it on a long road trip, I expect it to go up some more before leveling off.
    New observation:
    About a week ago, it started making a rumbling sound between about 45-53 mph. It sounds a little like driving over tar snakes except the frequency never changes with speed, nor does the pitch. I think something underneath is vibrating in the wind. I have an appointment at the shop for 11:00 this morning. I'm hoping the tech will have seen this before and it's a quick fix. I didn't find anything obvious by laying down and looking around with a flashlight.
  7. Bill Norton
    Bill Norton Senior Member
    2,146
    734
    MONW, Ks.
    Can I rain on this parade a bit?;)
    My Bolt has an 'Avg Speed' display. If this were reset before that 26.5 mile trip displayed above I'm sure it's going to show 'Slow'.
    It's just the nature of using power to push through the air.
    Slow uses little power. Fast uses a lot. And it's not linear.
    And you always have to factor in elevation changes, temps and winds on these tests.
    I'm just jealous...:(
    I get no where near these numbers. But almost all my driving involves a blast on the interstate for part of it.
    And I don't have the stock LRR tires on the front.
    And I enjoy the silent acceleration! It is not wasteful to flog an EV!
    0-60 mph in 10 seconds or 60 seconds. Same same. Physics!
    You want to hear a tidbit that has me shaking my head about the current Bolts?
    They deleted the coolant loop going to the drive unit.
    Look at this Munro video around the 5 minute mark:
    I guess gm knows what they're doing. (n)The synthetic ATF must handle the heat fine and not need the cooling.
  8. Trollbait
    12,518
    The Prius went three generations without cooling the ATF, and it's been fine:rolleyes:.
    Not sitting next to an ICE does a lot in keeping components and fluids cool on a BEV.
  9. ChapmanF
    18,146
    Maybe the Gen 4 thing is a more traditional-looking transmission fluid cooler?
    The earlier generations definitely had the coolant in the inverter loop pass through passages in the transaxle case to carry heat away from the oil, which is just on the other side of the aluminum in that same case.
    This pic of a Gen 3 or Prius v transaxle shows both the green area used for coolant heat exchange in both, and the purple area that is additionally used in the Prius v.
    Bill Norton and jerrymildred like this.
  10. jerrymildred
    11,517
    14,150
    Tampa, FL
    So does mine over on the DIC and it resets when I reset that trip meter. But this is since the last "full" charge, meaning since it was last charged to the limit I set.
    What a great setup for a sarcastic response, but I'll be nice; we're all friends here. :D
    That's what I keep telling people. But this is coastal Florida. My house is at most 10 feet lower than work.
    And that's the big difference. My new EUV has yet to be on and interstate
    This is true. Till it's time for new tires already. :eek:
    Wow! I hadn't heard about that. I wonder if that's also true for the heavier EUV.
    Update on the mystery noise:
    I took The Bolt From the Blue to the Chevy dealer yesterday. They have ordered a "Kent Automotive Adhesive Backed Shim Stock (5/16 thickness, 1 width)." It's due in about 10 days. The service writer said there was a TSB on it. So my theory that something was loose and bouncing was right except that it wan't a fastener but a loose or missing foam spacer. I'm guessing it was there but the adhesive let go since the noise didn't show up till almost three weeks after I got the car.
    I also picked up and installed the all weather floor liners I'd ordered. I already have grease marks on the carpeted driver's floor mat from driving in my work shoes.
  11. Bill Norton
    2,146
    734
    MONW, Ks.
    Yeah, I knew you knew all this stuff.;)
    I'm just that guy when someone posts their GOM displaying 300 miles range,
    and others chime in to praise them for that display and ask for techniques,,,
    I'm the one that will post:
    "That's easily attainable by anyone!
    Just drive 5 -10 MPH slower each day until you see the numbers that you want!":whistle:
    Sometimes it's a race for the slowest, like with the Prius and its 'Go Slow' display.
    Only with an EV there's no reason to accelerate at Prius rates to save electrons.(y)
    Oh, I just got back from Iceland and had a Yaris Hybrid for 10 days! In place of the tach there was a power needle.
    It's not a go slow like display
    And this engine seems to like to keep the RPM low and throttle open more compared to what I hear with my Gen3.
    Much less 'sing songy' from the engine.
    I'm sure it's not a Gen2 system like the Prius C was here for a while.
  12. Trollbait
    12,518
    People that did transmission fluid changes, even early ones, were reporting the fluid being burnt smelling.
    The above being adequate for heat intolerant automatic transmission fluid likely wouldn't have require Toyota announcing a transmission cooler added the the gen4.
    [/QUOTE]Probably just an aero shield.
  13. Bill Norton
    2,146
    734
    MONW, Ks.
    Sorry, Off Topic...:whistle:
    Smelling the ATF that is removed is not a scientific measurement.:unsure:
    And what about owners that followed the maintenance schedule and never changed the fluid?
    Even with the coolant passages in the transaxle?;)
    Keep in mind Toyota does not mention ever changing the ATF in the Prius Gen3 transaxle. Has that changed with later models?
    Similar to EGR system cleaning.....:(
    Check out this thread with many oil analyses posted: ATF fluid changes ARE Required. | PriusChat
    I started it when I was appalled at what came out of a used Gen3 I had just bought with 112k miles. It was so dark that the 'Particle Count' test could not be performed. I sent a second sample in when I changed it again ~400 miles later and that time it still showed particles of varying sizes.
    At least with the Bolt there is a maintenance schedule that includes Drive Unit Fluid change intervals.
    Only time will tell how important that deleted coolant loop is to the life of the Drive Unit.
    I suspect the worst case is: Arizona, 120°F, Road Racing on a track or climbing long mountain passes with your 'large' In-Laws loaded in the back and the full 200 HP is being used for extended times.
  14. Trollbait
    12,518
    First off, regarding maintenance items that have a 'lifetime' interval from the manufacturer, that lifetime is probably 150k miles, but can be 100k.
    To illustrate how mechanically simple the transaxle of the HSD is, it has been compared to a one speed manual with no clutch. Actual manuals use a gear oil for lubrication; some examples literally call for motor oil. These are fluids that can withstand high temperatures, and even some use cases require an oil cooler for the transmission.
    Gear oil should have been used in the transaxle, but the Prius was designed to minimize emissions and maximize efficiency. Lower viscosity fluid in the transmission will help with that. ATF is that and readily available. The latter means it is cheaper than working with an oil company to develop a new fluid for the application. The downside to ATF is that for a traditional automatic it does more than lubricate, and those needs results in the fluid being heat intolerant. The synthetic ATF Toyota uses should do better than the 200F breakdown point of dino-ATF, but it is still lower than what most gear oils can handle.
    I've hear car cooling systems are designed for towing through Death Valley during the summer. Which is why most of us can put in a partial grill block.
    According to this, https://gm-techlink.com/wp-content/uploads/2021/08/GM_TechLink_14_Mid-July_2021.pdf, the EUV retains that cooling loop. The cars' weights are under a hundred pounds in difference, but the EUV has a one ton tow rating.
    I'm not concerned with the removal of the loop on the Bolt EV; I'll still consider one. The gen1 Volt called for premium fuel. Part of the reason was because high octane has a longer shelf life. The data for in use cars showed that the tighter sealed gas tank worked as well as intended in real world conditions, so the engineers and accountants felt safe going with regular gas.
    This is likely the same situation. The data from all the cars being driven has shown that the drive unit doesn't need that cooling. Another possibility is that the internal components or fluid are better at withstanding the heat. This is just the removal of the cooling branch to the motor. The cost savings are low, and would need to be balanced with increased warranty claims if it was the sole purpose.
    #94 Trollbait, Oct 8, 2022
    Bill Norton likes this.
  15. Tideland Prius
    16,553
    At the risk of joining this discussion and getting dragged to the bottom of the pool instead....
    Why not? If anything an EV will have larger, more drastic changes in energy consumption between driving habits because of its efficiency.
  16. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    If you are driving an EV to minimize wasting energy, then you DO want to drive slower to save electrons. Faster acceleration decreases range, which means fewer miles per kWh or charge. If you don't care about that,, then the only downside to playing speed demon is the diminished life of the cells.
    This link has a nice explanation about the use of batteries designed for discharging over long periods of time VS cells made to discharge at high power rates. BU-501a: Discharge Characteristics of Li-ion - Battery University
  17. Bill Norton
    2,146
    734
    MONW, Ks.
    Yes, slower cruising speeds save electrons. Wind resistance increase by the square of the speed...
    But I respectfully disagree:
    Slower or faster acceleration rates have very minimal differences to 'range'.
    It's just math and it's different than flogging a gasser.
    Show us your references.
    I'll show mine.(y)
  18. ChapmanF
    18,146
    Higher acceleration rates in an EV entail higher current. I²R losses throughout the drivetrain, including across the internal resistance of the battery itself, increase by the square of I, the current. As you say, it's just math.
    Yes, please do.(y)
    Trollbait and Tideland Prius like this.
  19. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I included a reference in the above post. Clearly shows that the capacity in kWh drop as the drain (in amps) increases. Check it out.
  20. jerrymildred
    11,517
    14,150
    Tampa, FL
    While quick acceleration in an EV will take a toll on efficiency, that's mainly because there is more waste heat generated at higher amperages. That should be less of an impact than the higher fuel consumption due to the richer mixture demanded at big throttle openings. At least that's my theory. My experience with the Prime and with the Bolt (so far, limited) seems to fit the theory.
