Doing Hitches for Bike Carriers - Hitch Hauls - Mobility Chairs - Trailers
Discussion in 'Gen 2 Prius Main Forum' started by PriusCamper, Sep 3, 2022.
  1. PriusCamper
    PriusCamper Senior Member
    11,093
    4,515
    Pacific Northwest, USA
    So Happy to be trailering again!
    ColoradoCrow likes this.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,300
    338
    2013 Prius Plug-in
    holy balls of steel...
  3. PriusCamper
    11,093
    4,515
    Not sure how to take that... Can you clarify?
  4. MCCOHENS
    MCCOHENS Member
    189
    81
    Chalfont, PA
    I like it and will probably use the idea to tow my 400# sailboat/trailer rig. One comment, go to a truck spring shop and have some custom U bolts made up. The steel straps on the top of your bumper look like they are bending already.
  5. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    If I did this, I’d make two changes:
    1. Extend the length so it sits against the jack point.
    2. Use a thicker gauge steel and also use angle iron rather that flat steel.
  6. black_jmyntrn
    1,300
    338
    2013 Prius Plug-in
    let's just say I know with first-hand experience the crash bar has no strength... no way I would personally use it how you did... love the concept and will utilize some design options you used in my next build.
  7. ChapmanF
    15,569
    One key concern might be: that bumper reinforcement is made of aluminum.
    Every time the car accelerates, pulling the trailer ... subtract 1 from the number of flexes left on that reinforcement.
    Every time you brake, with the trailer pushing from behind ... subtract 1 from the number of flexes left on that reinforcement.
    On the other hand, if you can do all your driving on flat ground at unchanging speed, it's good for the long haul.
  8. black_jmyntrn
    1,300
    338
    2013 Prius Plug-in
    oh yes, I am fully aware.. issa why I removed the front and replaced it with steel...
