2014 Prius c - hybrid battery replacement - P0A80
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by blottoottoman, Oct 12, 2022.
  1. blottoottoman
    blottoottoman New Member
    2014 Prius c
    I have a 2014 Prius C with 209,000 miles. About a week ago, I got the P0A80 message. I've driven it about 400 miles since I first saw the message without any issues. I went to the Toyota dealer today & they quoted me $3,400.00 for a used hybrid battery (12 month/12,000 mile warranty) or $4,400 for a new one. The car's in decent shape (other than no air conditioning but I can live with that). I'm leaning towards installing the used battery. How long can I expect a used one to last? I drive around 25,000 miles/year.
  2. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    Why is the air conditioning not working?
    $3,400 is a lot of money for a used hybrid battery, are you sure that you went to a Toyota dealer? i don't think they sell used hybrid batteries.
  3. bisco
    52,390
    if you're going rebuilt, you can't expect anything except replacement during the warranty period.
    i would look around for a green bean battery or the like, if i'm going rebuilt. much cheaper, and better warranties
    blottoottoman likes this.
  4. blottoottoman
    2014 Prius c
    The AC stopped working a couple yrs ago. A trusted mechanic friend said that it would be $2,000 to fix the AC.
    Yes, it was definitely a Toyota dealership & they gave me an estimate of $3500 for a used battery & 4600 for a new one. I called a local hybrid auto shop & they said they'll jnstall a used one for $1500 total so I'll probably do that. I just hope the car doesn't leave me stranded in the meantime. Does it hurt the engine if I drive alot before I change the battery?
  5. blottoottoman
    2014 Prius c
    I checked out green bean, I hadn't heard of them. I'll contact them. Thanks!
  6. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Isn't it bad for the HV Battery lifespan not to use the AC? for the temps
  7. Sonic_TH
    574
    96
    Puerto Rico
    2016 Prius c
    But what stopped working? the compressor or the blower?
  8. PriusCamper
    PriusCamper Senior Member
    13,059
    5,305
    Pacific Northwest, USA
    Wow, that Toyota stealership is downright criminal for massively inflating prices. Don't go back to them! Going rate for a used OEM hybrid battery for Prius C is closer to a $1K and a bit over $2K for a new one, but they are on back order for months.
    Good news for you is that pre-order for Project Lithium packs began again today and all the supply chain challenges are finally behind them and they will likely have a steady supply indefinitely. This pack is not only half the weight of your existing pack, but it will boost your MPG, improve your AC performance and give you extra battery reserve power when climbing mountains and they're less than the cost of brand new OEM from Toyota at $1650. It' based on the most advanced and safest Lithium design of the past decade, whereas your current pack is based on technology from the early 1990's.
    If you use my affiliate link to purchase, I can provide unlimited tech support and help you find an honest auto repair shop to install it. Or I can walk a friend or family member who likes to work on cars through the installation process. It's a very easy install on a PriusC: https://projectlithium.com/?ref=9qLPw
  9. bisco
    52,390
    if you are in a hot climate, it might be better to feed the battery with conditioned air, although some have said there is no noticeable lowering of battery temps when read with an obd scanner
    Roqu3 likes this.
  10. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    AC is important part of hybrid battery air cooling. Without AC, Hybrid battery will fail prematurely.
    Never buy used battery unless you want to sell it within 1 year. Get a good new battery that will last another decade or more if you park in garage or under the trees.
