Canadian Tire Eliminator Ultra AGM Battery for Prius (w/Pics)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Nov 18, 2016.
  1. bisco
    48,985
    looks like it needs a charge. did you keep the old one?
  2. Siward
    Siward Active Member
    296
    124
    Toronto
    Don't have a charger. Maybe I will buy one later this year. I didn't charge it last time.
    Also, my multimeter maybe showing lower voltage. The Canadian tire rep measured 12.45V using his CCA tester.
  3. bisco
    48,985
    the problem is, the car only maintains the current charge. and then it drains while off.
    that's not good for the battery. best to charge it as soon as you can. canadian tire should charge it for free. a new agm battery is close to 13 volts.
  4. Mendel Leisk
    38,247
    Yeah, back in stock at my local CT now, and price up another buck now, to $250.99:
    https://www.canadiantire.ca/en/pdp/motomaster-eliminator-agm-group-size-s46b24r-battery-325-cca-0105122p.0105122.html
    SaskBattery recently quoted (via email, this battery NOT showing on their website), $229 CDN, for the OEM Yuasa (S46B24R-GS). That's with free shipping (presumably just within Canada), no core charge, and (if it's per my last purchase) only GST (5%?) levied, no PST ((7%?):
    Hi Mendel,
    We do have that exact Yuasa battery you're requesting. It's not currently on our webpage but we can ship for 229.50 plus tax (freight included). If you would like to proceed we can send a paypal request for you to complete for payment or we can take your credit card info over the phone.
  5. Feebz13
    Feebz13 Junior Member
    My 12V finally died on my 2009 prius with 230k kms. Replaced with the motomaster. Easy swap. The vent tube fit ok, not as good as stock but it's in there. I might have done something wrong, not too miffed about this.
    Not sure it will last as long as the Yusa but need the car to get to work and dealerships weren't open today. The old battery measured 9.8V! a few hours after removing.
    oops just realized this is for gen 3
  6. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    212
    109
    Canmore, Alberta, Canada
    Thanks for your comments. I found the Canadian Tire battery (now 271.99 +20$ core charge), and I emailed Sask battery. Lets hope they have something hidden away for me. Other than those two sources I dont know many other places to get a new battery from in Canada. Perhaps the dealers have them.
  7. Siward
    296
    124
    Toronto
    #27 Siward, Oct 13, 2022
  8. Siward
    296
    124
    Toronto
  9. Rocky Mountain Priusman
    212
    109
    I emailed SaskBattery and they quoted me at CAD $219.00 including shipping for a new battery. They stated they couldn't give me a brand name but that it would be the same specs as the Yuasa battery with the correct posts. I'm assuming this is the same battery Canadian Tire or Costco sells, probably a no-name brand that people slap their own branding on. I went ahead and ordered it. Will report back on exactly what I get.
    EfficiencyNerd and Mendel Leisk like this.
  10. Rocky Mountain Priusman
    212
    109
    Okay my $219 CAD (inc. delivery) battery just showed up from Sask Battery. Attached are some pics. Anyone want to weigh in on the specs as compared to the OEM or YUASA battery? Is this a good buy?
    Here is what it states on the battery:
    Part# FP-AGMPRIUS
    450 cca @ -18c
    550 cca @ 0c
    95 min r/c
    3 Year Free Replacement Warranty
  11. Mendel Leisk
    38,247
    The higher CCA than Yuasa probably means some reduction of Amp Hours. I'm completely out-of-my-depth, but have heard that as one increases the other (typically) decreases. FWIW, the OEM Yuasa's have lowish CCA and better than average Amp Hours.
    That said, the CCA is the same as our Optima Yellow Top (purchased from SaskBattery as well), and it's still going good, 7+ years on. I baby it though: only 3K kms usage yearly, and spends pretty much all down-time on a CTEK charger.
    See what it's volts reads, install it, see how it goes, report. If you really want to test it, something like Solar BA9 will do that. Automotive retailers selling batteries usually have pro-level testers of that ilk, and will usually test for free.
    Do you have decent smart charger? If so I'd do a session first. Clean the cable clamps before install.
    I'd dub the Toyota style hold-down bracket the worst possible design btw: ANY variation in battery height cannot be accomodated. Be prepared to either shim the battery up, or put washer(s) under the bracket's points of contact with car body.
  12. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Rocky,
    The CCA rating has no relevance in a Prius as the 12v battery does not start the engine and is never asked to deliver a high current. What is important is the Amp-Hour rating which is not shown on your battery.
    JeffD
    CR94 likes this.
  13. Rocky Mountain Priusman
    212
    109
    Yes, it is interesting that they did not include amp-hours anywhere.
  14. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    That generalization of ampere-hour capacity vs. CCA is true only assuming equal physical size. Making the plates thicker but correspondingly less numerous helps durability but not CCA.
    Yes, the original battery emphasizes capacity over CCA, because CCA is irrelevant in a Prius.
  15. ASRDogman
    ASRDogman Senior Member
    5,905
    3,167
    It's probably a chinese battery. Looking at the label, it's not a quality print job.
    That's your first hint. Only a 3 year waranty? OEM is 7 years.... for a few dollars more.
  16. Mendel Leisk
    38,247
    I checked OEM battery price with nearby Canadian dealership, within the last 6 months: they’re asking $340 (CDN).
  17. Rocky Mountain Priusman
    212
    109
    Tested the voltage on the new battery - 12.73 volts. I dont have a battery charger, though I see how it could be useful I dont feel like spending the money at the moment.
    I will report back on how the battery survives the winter. Seeing now that maybe i should have ponied up the additional 100$ for an OEM. Or maybe it won't matter.
  18. Mendel Leisk
    38,247
    That's good.
    Yeah give it a chance. (y)
  19. Rocky Mountain Priusman
    212
    109
    Thanks, Mendel for you support and comments. Got the new battery installed Very easy. Dimensions were extremely close to the original and the mounting bracket worked fine. Took the car for a short drive. There certainly were a few abrupt engine revs and I lost my radio settings but after a few minutes of driving car seemed to be its normal self.
  20. Mendel Leisk
    38,247
    Yeah that’s something I’ve noticed too, think the car is reestablishing some parameters.
