2015 Prius - Do I need new Tires? (pictures)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by crooner, Oct 27, 2022.
  1. crooner
    crooner Member
    107
    Yucca Valley, California
    I have a 2015 Prius Two with 115K miles. Back in January of 2020 I installed a set of Yokohama Avid Ascend P195/65R15's. I have rotated them regularly and kept pressures of 40 PSI in the front and 38 PSI in the rear. Fuel economy has been excellent and the ride quality has been very nice.
    Fast forward to October of 2022. The tires have now 40K miles on them. The limited tread life warranty on the tires is 85k miles. That could be unrealistic, I don't know.
    The tires look worn but not excessively so. See attached pictures.
    What do you guys/gals think? Are these things ready for replacement? Or can I squeeze a few thousand more miles out of them?
    The Yokohamas have been discontinued unfortunately. I would like to replace them with something similar although prices are much higher now for quality tires. The Bridgestone Ecopias are something I may consider as I do a lot of highway driving.
    Thanks in advance!
    #1 crooner, Oct 27, 2022
    52,335
    they look fine to me. you have tread wear indicators that aren't showing yet
    crooner likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    still good
    crooner likes this.
  4. crooner
    crooner Member
    107
    Thanks Bisco. That's good to know. They are pretty good tires. But I didn't want to trust myself or Discount Tire to tell me if they were good or not. I totaled my 2006 Tacoma in 2019 and someone said my tires were bald, and that's why I hydroplaned. I got the Prius afterwards. And Discount Tire, I figured they just want to sell me a set of tires, so I didn't even go there!
    #4 crooner, Oct 27, 2022
  5. crooner
    crooner Member
    107
    Thank you Sir!
  6. Tombukt2
    13,336
    2,401
    Run them down to the treadwear indicators then it's time to replace.
    crooner likes this.
  7. crooner
    crooner Member
    107
    Yes sir. Will do!
  8. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Just measure the tread depth. All the way to the wear indicators is risky if you live where it rains.
    Mendel Leisk, crooner and fuzzy1 like this.
  9. fuzzy1
    10,602
    Get a tread depth gauge to measure how much is left:
    Somewhere around tread depths of 1/32" (legal minimum in CA and a few other dry states) to 2/32" (legal minimum in states with rain) to 4/32" (recommended minimum by many, and legal minimum for some Canadian mountains in winter), replace the tires. But it looks like your tires have more tread than these guidelines.
    Though if it feels like the tires don't have enough remaining grip, don't be afraid to replace them earlier.
    Mendel Leisk, CR94 and crooner like this.
  10. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    In the picture 228758_20221027_155228.jpg (around 25% up from the bottom of the picture), you can see that you're very close to the tread-wear indicators (which are the bumps in between the treads).
    For driving in San Diego, the tires are fine, as long as you don't drive in heavy rain, or any dirt/sandy roads.
    In snow, those are death-trap tires.
    Hence, why location is often very important for accurate advice. :)
    crooner likes this.
  11. crooner
    crooner Member
    107
    They say it never rains in southern california, lol, but we are due for some downpours after years of drought!
    CR94 likes this.
  12. crooner
    crooner Member
    107
    I hear you. I'm planning on replacing them early next year. I was just hoping they could get me through the year at least...
    I drive in San Diego but I have a house in the high desert, so I drive over there every weekend. I noticed traction suffers when there's sand on the roads. Another consideration...
  13. crooner
    crooner Member
    107
    Thanks! I'll get one of those gauges. I noticed I lose traction on dirty roads sometimes, so that may be an indication the tires may be due for replacement soon!
    #13 crooner, Oct 27, 2022
  14. crooner
    crooner Member
    107
    Now, I am impressed at the longevity of tires nowadays. I remember I wore out the OEM tires on my 2003 Corolla at 25K miles or so. Admittedly those were awful Uniroyal Tiger Paws, and I used to drive aggressively back then too. Not to mention I wasn't careful about maintaining correct pressure and rotating the things...
  15. fuzzy1
    10,602
    While the wear bars are certainly visible in that picture, they are down at the bottom of the main channels, which still look respectably deep.
    Sand and dirt roads are inherently different than asphalt and concrete, regardless of your tires. So that isn't necessarily a tread depth problem.
    Some factory tires simply aren't the same as aftermarket, and can have shorter tread life, even if you don't drive aggressively. So that might not be the reason. Or maybe, not the whole reason.
    #15 fuzzy1, Oct 28, 2022
    crooner likes this.
  16. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Yes, shorter than for otherwise similar tires of the same brand, because the factory tires may have thinner tread in order to achieve higher EPA mpg.
  17. fuzzy1
    10,602
    ... or sometimes just to pinch pennies.
    crooner likes this.
  18. Tombukt2
    13,336
    2,401
    Hell my hard Michelin 100,000 mi tires whatever they call them now are about worn out they're gray they're almost to the treadware indicators they're on the front I can't even get them to slide in North Carolina in the heat in the rain It has to be extreme and then I might get a little chirp or her little slide but no sir I run them down to the tread wear indicators I'm looking for a little slide that's fun and then the tires come off the next day for the new ones that are out in the shop kind of like it's always been.
    crooner likes this.
  19. Mendel Leisk
    41,850
    Follow through on that; they’re cheap and indispensable. Me, I’d be at least window shopping for tires, anything less than 6/32”.
    some of the pics show more wear towards outer edge, which is kinda the opposite of what you normally see, due to neg rear camber (rear tires typically splay out at bottom, for more cornering stability).
  20. Grit
    Grit Senior Member
    6,575
    4,228
    Wilkes Land
    If this was summer now, you’ll be fine with the tread in the photo tit provided. But it’s going to rain so your stopping distance will increase due to lack of tread. If you continue to commute kB the highway in the next coming months, replace then now if the treads are around 3mm left
