Can someone tell me what this is?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ford Galaxie, Oct 30, 2022.
  1. Ford Galaxie
    Ford Galaxie Member
    63
    30
    Rome, GA
    2014 Prius v wagon
  2. burebista
    burebista Active Member
    188
    130
    Romania
    Mine looks bit different.
  3. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
  4. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    Persetrian Warning noise maker
    Elektroingenieur likes this.
  5. Tombukt2
    13,339
    2,401
    Must be UK thing tuv or something .
  6. Mendel Leisk
    41,858
  7. ChapmanF
    18,497
    But what's it doing way over by the starboard horn, instead of behind the fender on the port side?
  8. Elektroingenieur
    2,515
    3,287
    Three Touring
    The image is for the wrong model, actually, which highlights another regrettable deficiency of SimplePart’s catalog presentation on parts.toyota.com.
    If you select 2014, Prius, and then set the Trim Level to Hatchback, you get catalog code 224420, for Prius Plug-in cars, which aren’t listed separately by model name. Notice how Figure 82-01, Battery & Battery Cable, in that catalog shows the larger HV battery.
    If you set the Trim Level instead to BASE (VIN Starts With JTDKN3U), you get catalog code 222430, for liftback Prius cars. In this catalog, Figure 86-11, Horn, shows the vehicle approaching speaker assembly, part name code 86570, in the central location where it was photographed by @Ford Galaxie, with the note “※3 (1310–____),” indicating that this applies to vehicles made in October 2013 and later, that is, for U.S. model year 2014.
    Mr. F and Mendel Leisk like this.
  9. Matth Torrijos
    Matth Torrijos Active Member
    114
    208
    Poway
    What trim is yours prius
