Heated Seats
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jimlarge, Sep 9, 2022.
  1. Jimlarge
    Jimlarge Junior Member
    28
    MN
    I searched the threads and I didn't see anything.
    Where should I white the aftermarket heated Seats for power? I can install the button and the seat pads but where is a good place to get power that turns off with the key?
    Thanks!
    PriusJim
    51,840
    the cig lighter has switched power
    Jimlarge likes this.
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Jim,
    I installed heated seats in both our prii. I used a add a tap to the fuse box for switched power. I'm not sure which fuse I used but I did meter it and made sure it was a switched power connection. I'll take a picture the next time I am home.
  4. Jimlarge
    28
    MN
    Yes please post a pic, if you used the add a tap, were you able to put the cup fuse panel cover on still?
  5. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    no. The cover would not go back on so I just left it off. I get back to my car at the airport tomorrow afternoon. I'll try and remember to post. In my car I mounted the switches on the outside plastic of the seat itself. When I did my wife's car she wanted them on the left side of the dash panel on the drivers side. In hindsight I should have done that for mine as well. I just turn mine on and off by feel. It works fine. I used the Doorman seat heaters from Amazon. $40 each and well worth it. Its actually too hot on high for me even in Colorado
  6. ChapmanF
    18,070
    A good question about wiring a seat heater would be "how many amps does it use?".
    ColoradoCrow likes this.
  7. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
  8. dingaling007
    dingaling007 Junior Member
    Australia
    i-Tech
    Didnt the Japanese market Gen2 come with heated seats? The wiring could well be in there ready to tap into maybe.
  9. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    Sorry this is so late E502BBC8-00EF-4BE3-B973-8F0D5ADCD0BD.jpeg 0D829F2D-C743-4ACB-92C7-A3725ACE274F.jpeg
  10. Bob-oh
    Bob-oh New Member
    Wisconsin, United States
    Hey Jim!
    Where did you get your seats? Did you have perform any fancy electronic updates so the seats are recognized by the computer system?
  11. Bob-oh
    Bob-oh New Member
    I want to replace my base seats with electric in my 2016 Gen4 Prius.
