bulb size for the backlight of the Engine Start and Parking Button
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gptoyz, Jan 30, 2022.
  1. gptoyz
    gptoyz Junior Member
    83
    17
    los altos
    my interior backlight bulbs for the 2 buttons are burned out and I was wondering if anyone knows offhand what the bulb size is before I go tearing into my car
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    A little bit of a perfectionist? Digging into your car just for those 2 items might end up breaking other things. Maybe address those when you really have to dig into your car for something more significant.
    As these cars age, the clips and plastics around that area gets really brittle. Easily can break other things while you're going in there
  3. ChapmanF
    18,538
    How old is the car? This is the Gen 2 forum, but the OP's profile says 2010.
    But then, in Gen 3, I think those are LEDs and don't burn out.
    So assuming it's a Gen 2, this is the power button bulb, and this is the park button bulb.
    The last time I replaced those in a Gen 2, I also changed the shift lever backlight, this one (which, for some reason, is sold separately from its little green cap).
    I didn't have any trouble with the panels. A rule of mine is to use only the pads of my fingers, no pry tools.
    A Gen 2 could be anywhere from 13 to 18 years old now, and also the climate and amount of sun it has seen could be factors.
    #3 ChapmanF, Jan 30, 2022
    mr_guy_mann, gptoyz and PriusCamper like this.
  4. gptoyz
    83
    17
    los altos
    Oh this is on my gen 2 2009. I’ve had various prii over the years including a 2012 in the stable
    yes correct some of the plastic is very brittle that’s why I don’t want to take it apart put it back together and take it part again
    on Hondas, they are little tiny bulbs that use flat heads that quarter twist so I figure they are something similar on the Prius
    but yes…it does bother me. I fix everything I can on my 09. I’m currently 700 miles shy of the 300k club and I intend to hit 500k miles. So far, I’ve only replaced things with factory or better components. Take care of her and she’ll take care of me
    ydpplqbd likes this.
  5. ChapmanF
    18,538
    Yep, that's what they look like.
    I'm in favor of that approach. Stay on top of easy little things, and the car keeps feeling like something you want to take care of, so you do. Let a few unfixed annoyances accumulate, and that starts to change how you feel about it and approach it, and then that snowballs and before you know it you've got a jalopy.
  6. gptoyz
    83
    17
    los altos
    thank you got them all ordered up
  7. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Can you share part numbers? TIA.
  8. ydpplqbd
    551
    253
    Duplicate posting. I apologize.
  9. ChapmanF
    18,538
    Click the links in post #3.
  10. ydpplqbd
    551
    253
    Based on your links the part numbers are:
    1. Bulb "a": 90010-01061; and
    2. Bulb "b": 90010-01039.
    I don't remember which bulb is for the park indicator or for the start button indicator.
  11. ChapmanF
    18,538
    Look at the words around the links in post #3 ?
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,498
    Taylors, SC
    They are the SAE industry standard T5 bulbs. They cab readily be replaced with LED ones like these available on Amazon.
  13. ydpplqbd
    551
    253
    Park lamp bulb illuminates ias green. And, the START lamp has two colors: i.) green; and ii.) orange/amber.
    How do these T5 bulbs create the correct colors?
    My understanding is that the START bulb has two different states when illuminated: a. orange/amber; and b. green. Does anyone whether my understanding that one START bulb creates two different colors is correct?
    #13 ydpplqbd, Feb 3, 2022
  14. ChapmanF
    18,538
    There's a multicolor LED inside the power button for status indication, but its illumination backlight (illuminates the word "POWER") is not that. It's one of those old-skool standard tiny incandescents (in Gen 2) wearing a green cap.
  15. Kiowa
    Kiowa New Member
    New Zealand
    2012 Prius Alpha
    Does any know how to replace the little bulb that illuminates the word power? Is it as simple as removing the button cover or do you need to dismantle the power switch (eeek!)
  16. Georgina Rudkus
    3,511
    2,498
    Taylors, SC
    No bulb...It's LED's. The buttons seldom fail. They car cheap on eBay.
  17. ChapmanF
    18,538
    This is the Gen 2 forum, and in Gen 2, the illumination backlight for the power button is an incandescent bulb ... as covered back in post #3, which linked to its part number.
    It isn't hard to replace. As you see in the picture, it's just in a little twist-out on the bottom of the power button housing.
  18. Kiowa
    Kiowa New Member
    New Zealand
    2012 Prius Alpha
    Thankyou so much for this - that makes it much clearer.
  19. 2genowner
    2genowner New Member
    Rhode Island
    for those still looking I just installed these in both the park and power switch. they are green LED. being LED some (like these) are sensitive to power flow (polarity) and will only work when in correct so if you install and they don't work flip the bulb socket 180 degrees. I would suggest checking before re-assemble
    Green T3 Neo Wedge 3030 SMD Chipest 8mm Base Led (comes as a 10 pack)
    Looks like links not allowed Amazon search for (comes as a 10 pack)
    WLJH 10x Green T3 Neo Wedge 3030 SMD Chipest 8mm Base Led Car Instrument Cluster Dashboard Gauge Bulb HVAC AC Heater Climate Controls Lamps Switch Indication Interior Light Replacement
    I also change while apart the Shift knob bulb to a LED. they did not have green so I picked ice blue
    T5 LED Bulb (comes as a 20 pack)
    74 Led Bulb Dash Lights Super Bright, T5 37 74 LED Bulb with Twist Lock Socket PC74 PC37, Dashboard Lights, Instrument Cluster Bulbs Kits,Pack of 20 (Ice Blue)
    #19 2genowner, Nov 6, 2025
  20. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    The power switch LED is a green/orange combo LED, is it not?
