Repair questions - 2011 Prius 245k miles
Discussion in 'Gen 3 Prius Main Forum' started by Ds001001, Oct 19, 2022.
  1. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    I did buy a new egr valve , didn’t even think about a pressure washer.. hopefully that works and don’t have to pay the $300 for a new one.
    Just replaced the water pump, much easier than getting the egr cooler off. I finally defeated the nut under the cooler but my hands are way beyond scraped up and had to make a Reno run for deep sockets that I didn’t have why can’t Toyota spend a couple hundred more on the cars to smooth out all the edges !!?!!?
  2. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    I don’t have a pressure washer but I suppose a few $5 in quarters minimum on the car wash in town will be worth not having to buy a new one. Good idea on the oven cleaner , thanks !
    ASRDogman likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,196
    3,766
    You can get a pressure washer for $100. That's what I paid for mine a few years ago.
    I don't think they've gone up much since. You can check online at the different stores...
  4. Mendel Leisk
    40,553
    See second link in my signature for water soluble approach to cooler carbon busting.
  5. rjparker
    9,566
    5,875
    When its totally clogged and hard from end to end, a wire on a drill works. That condition generally means you have excessive oil consumption. Since you intend to replace the engine next summer, I would not get too carried away with this engine. Get a rebuilt replacement by saving the "maintenance" dollars now.
  6. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Thanks for the idea, used a coat hanger and was able to dig in and am making progress
    Are you suggesting that I don’t put a new egr valve on it due to the likely oil consumption ?
  7. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Already had some oxy clean…your suggestion working good..been soaking for a few hours and finally getting some drips through when holding vertical and poking with clothes hanger wire. 3 day snowstorm about to hit so will keep at it .
  8. douglasjre
    douglasjre Senior Member
    2,092
    700
    Null, NL
    Where do you obtain used OEM cats?
  9. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    I bought this one, where I live don’t have to use the oem cat. in combo with Denso downstream o2 sensor I have no codes after installed
    https://www.ebay.com/itm/303890171766
  10. douglasjre
    2,092
    700
    Null, NL
    How many miles and how many warm-up cycles do you have on this cat so far
