Peeling paint on black plastic trim triangle behind diver rear door
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Biscuitman, Nov 16, 2022.
  1. Biscuitman
    Biscuitman Junior Member
    Ottawa
    Technology
    Just noticed that the coating of the plastic is starting to peel in a few places. Can this be fixed by spraying DIY or will the piece need to be replaced?
  2. Mendel Leisk
    41,900
  3. Biscuitman
    Ottawa
    Technology
  4. Biscuitman
    Ottawa
    Technology
    Just had fresh snow so the peeling is not visible at present , very odd!
  5. Biscuitman
    Ottawa
    Technology
    Our Prius is a gen 4, sorry I put this post in the wrong category.
  6. Mendel Leisk
    41,900
    Ah ok. Yeah, fairly common 4th gen issue; it can be popped out "relatively" easy IIRC. You could replace, or respray. If a pro does the painting, maybe replacement would be cheaper?
    Reported btw, mod's will move.
    Biscuitman likes this.
  7. orangecones
    orangecones Member
    46
    28
    NZ
    Mine started to peel a couple months after I bought it (a 2016, bought in late 2021). Just today had the replacements delivered. Ordered on ebay, they shipped from Japan. Hopefully be getting to installing them in the next weekend or two. They are around $160 USD for both sides, and you can find a couple videos on youtube on how to do it.
  8. Alex2323
    Alex2323 New Member
    2018 Prius
    I had the exact same issue on my 2018 Prius Three. The glossy film on the plastic panel was peeling off.
    I ordered a replacement panel from the parts department of my local Toyota dealership back in November 2022. Was able to take advantage of an offer going on at the time. The price (before tax) was $86.39. The offer included free shipping, so I had it shipped to my home.
    I got busy/lazy and it sat in its box until today. I just installed it 15 minutes ago. It was fairly easy/straightforward thankfully. Carefully popped the old one off, cleaned underneath, and then carefully popped the new one on. The only other thing I had to do was clean off some old adhesive residue and peel the backing off the adhesive section on the new one. It's mostly fastened with clips, but there is one tiny area in the corner where there is an adhesive pad.
  9. Gabster099
    Gabster099 New Member
    Los Angeles
    Hey there,the same happened to me,the panels are expensive,I vinyl wrapped the panel,it looks like new.
    I bought the vinyl on Amazon,I removed the panel(or you can leave it on the car) and do the wrapping,I recommend this method.
    Kenny94945 likes this.
