very low instrument lighting
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by RichardAllen, Nov 22, 2022.
  1. RichardAllen
    RichardAllen Junior Member
    Des Plaines IL
    Four Touring
    The left side of the instrument panel is hardly lit on my 2016 Prius. What is the cure?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    Hrm, may be that the panel's lighting is dying. One thing to check is the dimmer switch on that panel by your left knee. Increase and decrease it to see if that helps any.
  3. RichardAllen
    Des Plaines IL
    Four Touring
    Thanks, it was the dimmer switch
