Unanswered questions about new Prius
Discussion in 'Gen 5 Prius Main Forum' started by adric22, Nov 22, 2022.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The optimal solution, in my opinion, was PHEV with an H2 fuel cell range extender. But Must so severely poo-pooed hydrogen and fuel cells and so pushed BEVs that we're too late for the optimal design so now we have to make the best of the sub-optimal BEV solution.
    The good news, is BEVs are optimal if we end up with good batteries. With today's batteries, they kind of suck, but if we had batteries 2-3 times better than we have now (which may happen in the next decade or two), this solution will have "hit the ground running" on the back of the current mediocre batteries.
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    And that may come, just not sure why Musk is at fault. I don’t expect the current EV technology to last too long, that’s partly why I hesitate buying anything right now. My 2014 is running great, so I’m in no real hurry, though I would like sone if the new tech stuff.
  3. Sammyd
    Sammyd New Member
    2016 Chevy Volt
    There are YouTube videos showing the next 10 years of Toyota vehicles. Many BEV’s planned. Does one of them have to be called Prius to make you happy? If you don’t need an ICE anymore, I would recommend you buy a BEV then and leave the Toyota lineup as they don’t really offer a competitive BEV yet.
  4. Sammyd
    Sammyd New Member
    2016 Chevy Volt
    Toyota doesn’t have battery supply to make BEV’s at volume. Either does most every other manufacturer not named Tesla.
  5. bisco
    52,421
    musk isn't the problem, hydrogen is. it's obvious, watching the billions that have been invested by auto manufacturers, and tax payers.
    if musk had decided hydrogen was a better option, he'd have been relagated to the history books by now.
  6. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I totally agree, bisco.
  7. Trollbait
    12,693
    The feds nearly pulled the plug on hydrogen before Musk invested in Tesla. Cheap natural gas saved it. But that wasn't enough to overcome the issues facing hydrogen infrastructure. Perhaps a plug in hydrogen car would have lessened those issues enough for success, but no one that wanted to make hydrogen cars wanted to make one. Musk didn't prevent that.
    DoubleDAZ likes this.
  8. Lee Jay
    5,850
    4,036
    No, but I want the most efficient lift back.
    No one makes a good one.
    The Ioniq5 is not efficient enough. Same with the EV6.
    The Model3 has no dash and is made by a company at the bottom of the quality scale, plus it's overpriced and the controls stink.
    The Ioniq6 isn't a lift back.
    The Ioniq EV lacks range.
    The MachE isn't efficient enough and some total idiot attached the "Mustang" name to it.
    There are simply no decent EVs available.
  9. 3PriusMike
    3,101
    2,419
    Silicon Valley
    Perfect is the enemy of good enough
    Mike
    Trollbait likes this.
  10. Gokhan
    Gokhan Senior Member
    6,561
    2,618
    Paramount CA
    Mostly guesses:
    • What is the EPA driving range
      • 42 mi
    • What is the charging rate on 240V? (I'm hoping for 6.6 Kw)
      • C/2 (2 hr)
    • What is the output of the solar panel?
      • 300 W
    • Does the solar panel charge only the 12V or high voltage system? (I've heard claims both ways, so I'm not sure who is right)
      • both
    • How problematic is the placement of the instrument panel? I'm concerned that with my favorite driving position, the steering wheel may be blocking it.
      • nonissue because of adjustable seat and steering wheel
    • What is the 0-60 time in EV mode without the ICE?
      • 10 s
    • What kind of thermal management does the battery have?
      • same as before
    • Are they going to make more than token amounts of the Prime like they've been doing with the Prius and Rav4, or are they going to build to demand?
      • will be built to far below demand
    #30 Gokhan, Nov 24, 2022
  11. Tideland Prius
    16,623
    With the right wheel and tire, it can be.
    I’m running FAST EV01 19” wheels on Nokian Hakkapeliita R5 EV winter tires and got >5 mi/kWh. I’m usually in the 3.5-4 kWh range on the stock 20” rims.
    drash and Gokhan like this.
  12. Lee Jay
    5,850
    4,036
    None are close.
  13. Lee Jay
    5,850
    4,036
    Not good enough.
    I'm usually in the 6 miles/kWh range on my Prime and I'd like an improvement over that.
    I'm getting around 75 on my ebike and trying to improve that to 100.
  14. Mendel Leisk
    41,956
    I think the harder truth is, mankind has got to scale back expectations about their “rights”, to drive incessantly, get out-of-season produce and cheap tech from halfway ‘round the world, and never “stoop” to using public transit. Birth control wouldn’t hurt either.
    drash, mountaineer and bisco like this.
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Can you post pic of your Drive Monitor 2 showing that you actuary have 6miles/kWh life time average?
    Tideland Prius and bisco like this.
  16. Lee Jay
    5,850
    4,036
    I don't. I have a 5.1 lifetime average. It's about 6 in the summer and about 4.2 in the winter here in Colorado. Since we're just coming off summer, it's been about 6 since about last March.
  17. Lee Jay
    5,850
    4,036
    The biggest losers in our lives are mostly that conventional cars are absolutely hideously inefficient devices (quite often 3% of the mass is cargo, and the engines are 25% efficient for an overall efficiency of less than 1%), our building shells are mediocre at best, industries are not at all focused on energy efficiency, and our methods of electricity production are averaging under 50% efficiency.
    Ships at sea are actually very efficient as are trains, though both need to stop using diesel even though they use it efficiently.
  18. Mendel Leisk
    41,956
    How ‘bout that Starbucks drive-thru line-up, all those zombies in their vehicles, heads down in the glow of cell phones, inching toward coffee an’ donut.
    Watched this show, somewhere around Borneo*, a class of people who aren’t even allowed ashore, live their lives either on boats, or huts on stilts. Life expectancy 30~40 years.
    * More info here, episode 2:
    Survivorman - Beyond Survival - Les Stroud - Survivorman
    #38 Mendel Leisk, Nov 24, 2022
  19. Lee Jay
    5,850
    4,036
  20. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    There are plenty EVs you could consider. Prius doesn't have to be a car for everybody. No car can tick every checkbox of everyone.
