Faint "siren" Noise Upon Engine Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by broski, Jul 26, 2022.
  1. broski
    broski Junior Member
    44
    MN
    Hi All,
    I'd like to get some guidance as to what I might want to investigate with my 08 Prius. 80k miles. The symptom is a faint siren-esque noise (almost like there was a police car approaching from half a mile away) coming from the front of the car when the car starts. It is not audible once the car starts moving. It is reproducible but seems to be less present on a hot start. The noise will occur regardless of if the HVAC is on or off.
    Any ideas?
    edit: I should note. Coolant levels for the engine & inverter are both good. Serpentine belt was replaced last year.
    #1 broski, Jul 26, 2022
    52,286
    is it the old fashioned siren or the newer euro style?
  3. PriusCamper
    PriusCamper Senior Member
    12,986
    5,281
    Pacific Northwest, USA
    Is is possible the serpentine belt that was replaced is when this noise began? Or soon as it was worn in? How does belt tension seems?
    Thinking you oughta get an auto stethoscope or hold a screwdriver up to your ear and pinpoint the source.
  4. broski
    44
    MN
    It's been about a year since the belt change, but I agree, perhaps the tension on the belt has gotten loose. My other thought was the idler pulley bearing starting to go. It's very faint but the sound is there. Perhaps I'll try and capture it.
  5. PriusCamper
    12,986
    5,281
    I did an idler pulley on a Honda hybrid once. When you hold a long stick up to your ear with the other end on the pulley bolt if that's the problem it will be certain. You might need to take the right front wheel off to get access to it though.
  6. broski
    44
    MN
    Ok, some update here.
    I notice the sound changes if I shift into N, so it's likely related to the transmission mount I recently replaced. The mount was aftermarket and appears to be significantly stiffer/of worse quality than OEM as it transmits a very noticeable amount of noise over the old OEM one, even if that one was torn.
  7. broski
    44
    MN
    Replaced the aftermarket trans mount with a proper OEM unit. Noise is gone and car is significantly quieter and comfortable. Never buy anything besides OEM rubber.
    mr_guy_mann likes this.
