Steering wheel control for new radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by Prius1mil, Nov 28, 2022.
  1. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    Just ask Crutchfield. They know the correct adapter to use for a Gen 2 Prius.
  2. Prius1mil
    Prius1mil New Member
    Dfw
  3. dolj
    dolj Senior Member
    8,553
    4,344
    Some adaptors incorporate the resistor and some do not. You probably should ask Crutchfield if the recommended one does.
  4. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    If you buy the Metra 99-8240B mounting kit, it comes with the resistor you need.
