Hybrid Pit Stop
Discussion in 'Gen 3 Prius Main Forum' started by AzusaPrius, Sep 19, 2021.
  1. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    1.5” Front and Rear
  2. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    2 Gold Package Engines getting prepped to be shipped out of State!
    Minnesota and Pennsylvania will be the final destination for these builds
    mikey_t likes this.
  3. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Just a small detail that gets replaced on every rebuild!
    This is an oil control filter that helps operate the Variable Timing Solenoid.
    Show a picture of this to your mechanic and if they have no clue what it is then……Run
    Montgomery, mikey_t and ASRDogman like this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,438
    2,400
    Taylors, SC
    That's another reason for more frequent oil and filter changes.
    Grit, Foxglove and RightOnTime like this.
  5. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    On to the next Chapter!
    This is our 1st Engine build using a brand spanking new Toyota Block assembled from the Factory. This includes the 2015 revised pistons and rings which is a game changer.
    Of course we added some goodies such as a powder coated valve cover so we can own this build!
    For Sale
    Xterra72, ockevin, mikey_t and 5 others like this.
  6. Mendel Leisk
    41,289
    So if you buy a new short block these days, it WILL have revised pistons/rings? I’ve wondered about that.
    mikey_t, Montgomery and RightOnTime like this.
  7. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Yes indeed
    mikey_t, Montgomery and Mendel Leisk like this.
  8. ASRDogman
    ASRDogman Senior Member
    7,533
    3,892
    RightOnTime likes this.
  9. PatrickBrian
    PatrickBrian Junior Member
    62
    40
    Pittsburgh
    2014 Prius v wagon
    No concerns about the paint holding in the heat?
  10. ChapmanF
    18,045
    Has that guy got a part number? I looked around on parts.toyota.com for a while once to find it, and had to admit defeat.
  11. PatrickBrian
    62
    40
    Pittsburgh
    2014 Prius v wagon
    Where is that guy hiding? I don't recall seeing it, but it looks like it could be important.
  12. ChapmanF
    18,045
    Kind of buried inside the no. 1 cam bearing cap. See callout 15678A, here:
    ... which means I just answered my own question about the part number; 15678-0V010.
    Somehow I had found that drawing back in January, then admitted defeat trying to find it again.
    PatrickBrian likes this.
  13. PatrickBrian
    62
    40
    Pittsburgh
    2014 Prius v wagon
    That explains why I didn't see it, and thankful Hybrid Pit already replaced it.
    Is this going to be another maintenance item on top of the EGR cooler cleaning? I think my next vehicle is going to be a Model T.
  14. ChapmanF
    18,045
    In most cases I think it'd be a good thing to leave well enough alone, unless for some reason you're going to have the valve cover and that bearing cap off anyway.
    I've rarely seen a picture of a badly gloopy one here, and I think only in engines with very neglected oil. Even the 'old' one shown up in post #83 I doubt was having any measurable effect on engine operation.
  15. Mendel Leisk
    41,289
    Could be easily cleaned? Would maybe be good to include in the gasket rebuild kit.
    mikey_t likes this.
  16. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    So far so good! We use special high temp engine paint
  17. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Our OCD made us change it
  18. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Good question!
    We completely tear down the assembly to check cam tolerance, bearing cap wear and many parts mentioned in the Toyota Bible!
    Now do you want to take that risk by not taking it apart? It scares me to type that, but we have a whole box full of beat up assemblies that did not make the cut
    Simple mechanic don’t got time for that - but we treat every job like it’s our own car Señor ChapmanF
    Xterra72 and Montgomery like this.
  19. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    That’s the part! View attachment 234197
  20. ChapmanF
    18,045
    I was replying to the post immediately before mine, which asked:
    Often I will [quote] a post that I'm replying to so the context is clear, especially if some other posts came along in between. But sometimes I don't if it's really the post immediately before mine.
    You guys are rebuilding engines, and you already have them disassembled to check other things.
    I was responding more to the idea of "gee, I've got a Prius, should I disassemble my engine down to the cam bearing caps now and then so I can fiddle with the OCV filter?"
    My concern there would be a larger chance of causing iatrogenic problems than of accomplishing anything useful.
    Paul E. Highway likes this.
