Prius value
Discussion in 'Gen 3 Prius Main Forum' started by CVX20, Nov 24, 2022.
  1. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    The Priuschat moral police will pull me over and put me in cuffs but spray it with a coat of rubber in a can on the rust and sell it to carmax. I’ll edit this post when the red win wears off to tomorrow morning.
  2. douglasjre
    douglasjre Senior Member
    1,773
    617
    Orlando, FL
    Tony I love the car as much as you do but Bisco is right.
  3. bisco
    48,988
    i guess if the brake actuator, inverter and head gasket were only several hundred dollars each to repair, it wouldn't be that big a deal. but when people get quoted $2-3,000. for each repair, and they have to decide if it's worth it because the car isn't worth much more, that seems problematic
  4. Mendel Leisk
    38,247
    Also, the prophylactic maintenance to avoid head gasket failure is regular EGR and intake manifold clean-out, say every 50k miles.
    Toyota doesn’t want to know about it, dealerships flat-out WON’T clean parts, just replace (about a grand USD worth). And the labour likely about another grand.
    independent shops that’ll take a more sensible approach are few and far between. Tampa Hybrids and The Hybrid Pit Stop (LA area?) are pretty much the options?
    owner get togethers were effective, @Raytheeagle and @Grit organized those. (y)
    Raytheeagle likes this.
  5. ASRDogman
    ASRDogman Senior Member
    5,907
    3,167
    $3000 is a lot less than $30,000....
